Wood Painting Conundrum! - Painting - DIY Chatroom Home Improvement Forum
Old 12-06-2013, 06:37 PM   #1
Question
Wood painting conundrum!
Hi all,
I have just moved into a new house and I wanted to update the bathroom cabinets. I can tell from looking inside that they were originally painted a sky blue color. The previous owners painted them an off white color.
I have painted them with three layers of Rustoleum Ultra Cover Premium Latex Paint in semi-gloss white. HOWEVER, for some reason the original sky blue color keeps seeping through, and now the whole thing is a very light blue.
Where am I going wrong? Could it be that iíve painted a latex paint over a water based paint for example? Should I be painting a primer over the whole lot and starting again with a water based paint?
Hope someone can help me, iíve got myself in a right muddle!
Thanks,
Lauren
LaurieHK is offline   Reply With Quote
Old 12-06-2013, 08:34 PM   #2
K&B Designer
Live_Oak's Avatar
Prime with a shellac based primer like BIN. But be aware that the number of layers of paint that you describe can start to hide any details in the wood and make operating the doors difficult if they are inset. It's a stopgap measure only until you can replace the cabinets. Or, if there have some intrinsic value, such as they were made of birdseye maple under all of the archaeology, you can try stripping them to restore them.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 12-06-2013, 08:41 PM   #3
Thanks!
Hi Live_oak,
Thank you for your reply, itís really helpful! Iíll try and get hold of a shellac based primer and give that a go. What type of paint would you suggest to go over this type of primer? Do you think iím ok to continue using the Rustoleum Ultra Cover Premium Latex Paint in semi-gloss white over this primer?
The cabinets have no value, itís just a stopgap solution until they can be replaced. If any of the doors start to stick, I think iíll just sand down the sides for now.
Thanks again.
LaurieHK
Old 12-06-2013, 08:54 PM   #4
Gymschu's Avatar
Rewards Points: 490
It might not be the paint, it might be technique, quality of brushes/rollers, and/or not putting on enough paint. I will say that the RustOleum latex is not a good coverage paint. I have used it on metal doors and had to apply 3 coats.
A shellac based primer like Zinsser's Cover Stain is good stuff, but it smells to high heaven. If you don't like strong fumes, try Zinsser's 1-2-3 which is a water-based bonding primer that sticks to anything. Problem is, you would be starting all over if you decide to prime now.
Gymschu is online now   Reply With Quote
Old 12-06-2013, 08:56 PM   #5
Shellac-based primer
Laurie, the Bin primer is available everywhere . . . but be very careful, its FUMES are AWFUL, you'll need serious, constant ventilation. Get out of the room every few minutes.
corindo is offline   Reply With Quote
Tags
latex paint , paint and primer , problem
need advise with wood rot before painting 629RWHPstang Painting 6 04-30-2012 10:22 PM
Painting wood paneling Michaelpro Painting 24 02-27-2012 10:49 PM
painting wood fiber ceiling tile sys72db Painting 4 09-25-2011 02:19 PM
Painting over dark wood doors violet_uk Painting 1 09-20-2010 05:51 PM
Painting my wood panel joefromcal Painting 3 05-03-2009 06:23 PM
