Wood Overhang Exterior - Painting - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 09:54 AM   #1
Hi, my name is Kim
Which one is the longest lasting?
Should I remove the old stain, or should I clean-up thoroughly, and paint or stain over?
Thank You,
danielpettibone is offline   Reply With Quote
Old 09-22-2012, 11:06 AM   #2
Gymschu's Avatar
Rewards Points: 836
Not much info to go on.......but, I assume you are restaining your overhangs? I would gently pressure wash them, allow to dry for several days, and then apply 2 coats of stain. Is it semi-transparent? Is it solid color stain? If it's solid, I really like Sherwin Williams Woodscapes. I have used it for years and if you prep properly and apply 2 coats you could easily get 8-10 years out of the stain on overhangs.
Gymschu is online now   Reply With Quote
Wood never painted first when building exterior structures? darsunt Building & Construction 5 08-01-2011 12:48 PM
Is this exterior wood salvageable? drh Painting 3 06-08-2009 06:42 PM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 02:23 PM
cleaning and painting exterior raw wood shorty46 Painting 4 06-18-2008 05:14 PM
Exterior Door: is there a middle ground between a factory unit & a solid wood custom? pdks Building & Construction 1 04-14-2008 11:08 PM
