Old 05-20-2012, 12:16 PM   #1
wood ceiling help
I have a log cabin that has a ceiling made of 200 yr old barn wood. We are wanting to stain it solid but there are large voids between the planks that are allowing the blown in insulation to fall through the cracks. some of the gaps are 3/8 inch most are less than a 1/4. please help me with any solution to fill these voids
mich77fan is offline   Reply With Quote
Old 05-20-2012, 02:51 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
wood ceiling help
It's called Chinking-
I googled this:
http://www.westernloghomesupply.com/...-sealants.html
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-20-2012, 02:53 PM   #3
wood ceiling help
And all the heat or cooling is also leaking into the attic.
There is nothing that would look right to fill the gaps with.
You could remove the insulation, add a vaper barrier in the attic, air seal it then reinstall the insulation. Or go over the whole ceiling with new T & G material to seal it up.
Old 05-20-2012, 06:43 PM   #4
sdsester's Avatar
wood ceiling help
1/4 inch gaps might be worth tackling with a sealer. 3/8" would worry me a bit but it seems like you may have no choice.
sdsester is offline   Reply With Quote
Stripping solid wood ceiling paint Crusher Painting 5 01-29-2011 01:03 PM
An extensive 'drop ceiling' project- where to begin... kpatten Remodeling 7 02-05-2010 07:31 PM
Suspended wood ceiling panels (basement) High Gear Building & Construction 4 12-30-2009 11:06 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 06:30 PM
