Wiped Wall - Now The Texture Looks Different - Painting - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 05:04 PM   #1
Wiped wall - now the texture looks different
Hello all,
We painted about 10 days ago, today I wiped part of wall with a wet cloth, now that part "shines" in different light from the wall around it.
Any suggestions on how I can fix this without having to roll over the affected area again?
Regards,
matthewsw is offline   Reply With Quote
Old 02-23-2013, 05:12 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Cheap paint ( maybe?) that you did not wait long enough to cure. You will need to paint it again, probably the whole wall if it was not flat paint. You should wait about 30 days before trying to "wipe" it
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (02-23-2013)
Old 02-23-2013, 06:55 PM   #3
Rewards Points: 5,974
You don't say what kind of texture it is so I will take a guess and say maybe the texture had not completely set up then you used a water based primer and paint and this softened the texture and when you wiped it it flattened. If this is true you will need to let it cure then sand the spot, retexture, prime and paint.
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 12:57 PM
texture on wall vs. spackled spots diylady Painting 9 12-19-2007 03:01 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
