Window Stool Staining - Painting - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 03:45 PM   #1
window stool staining
My house was built in the 20's. The interior trim has always been painted and is all southern yellow pine, except for the window stools. I am unsure what variety of wood was used. Under the original layer of primer the stool was coated with with something (varnish?) that is now dark black. Despite stripping the stool with peel away stripper, sanding, and applying numerous coats of water based stain killer, I still get a cranberry red color stain bleeding thru my finish coat of paint. After the stain killer I apply 100% acrylic primer and two finish coats of enamel trim paint.
Has anyone encountered this, or have a suggestion?
sonofrus is offline   Reply With Quote
Old 09-22-2010, 08:57 PM   #2
Rewards Points: 101
If you're getting bleed through I recommend Zinsser B-I-N Alcohol based stain killing primer. It's very thin and drys fast, you may need a couple coats but this will hold back any stain or bleed through. You may also want to wear a respirator or open your windows for fresh air while using this product. Also I recommend using a small white china bristle throw away brush as it is a pain to clean, all paint and hardware stores have them. A 2" brush will cost less then a dollar. Once you prime with the B-I-N you're good to paint.
JMDPainting is offline   Reply With Quote
Old 09-23-2010, 10:02 AM   #3
Thanks for the suggestions. I had opted for the other stain blocker because of the easy clean-up but tossing the brush is even easier.
Old 09-23-2010, 10:14 AM   #4
Stain blocking Primer
I agree with JMDPainting
Zinsser makes great primers. Another option would be oil based coverstain, it also dries quickly and does an excellent job blocking stains. The upside is the smell it is much less potent. Either option will work.
Pearl Painters Portland Oregon
www.PearlPainters.com
Pearl Painters is offline   Reply With Quote
Need help for window stool plannng creamaster Carpentry 2 03-28-2010 03:12 PM
help with window stool SteveBman Carpentry 4 01-28-2010 11:54 AM
New and need help w/ window stool Fingersallacct4 Remodeling 3 08-27-2009 05:43 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
