Old 08-12-2012, 12:55 PM   #1
Window Sills/Borders White
I would like to redo my windows sills and borders. I would like to paint or replace them. Of course painting the inner sill would be best but I'm thinking of replacing the borders. Could someone provide suggestions on painting? I believe they have a light stain on them now. I attached a few pics. Thanks
tate16t is offline   Reply With Quote
Old 08-12-2012, 01:43 PM   #2
Gymschu's Avatar
Generally speaking, you will have to scuff sand them a bit........you could even use a sponge sander for this purpose. Vacuum up the dust. Then you must apply a bonding primer to give your topcoats something to "bite" onto. In your case you may want to use an oil-based bonding primer because those windows look as if they have been stained and clear-coated. If you use a water based bonding primer, you risk the chance of staining/bleeding of tannins/oils, etc into your finish coats. On second look, you may NOT have any clear coat on those windows in which case you should definitely use an oil-based bonding primer.
The Following 3 Users Say Thank You to Gymschu For This Useful Post:
ltd (08-12-2012), sdsester (08-12-2012), ToolSeeker (09-29-2012)
Old 08-12-2012, 03:43 PM   #3
Thank you for your response. You're right there's no clear coat.
I beleive this is a personal preference however would you replace the borders/trim or paint them?
Old 08-12-2012, 06:40 PM   #4
sdsester's Avatar
From what I can see, the trim looks to be in decent shape so unless you do not like the millwork pattern, I certainly would not replace them. For one thing it will be somewhat expensive and you will have to fit them which can be labor intensive.
If you are not sure. Sand, prep, prime and paint one section to see if you are happy with the look. Then make your decision.
sdsester is offline   Reply With Quote
Old 08-12-2012, 07:26 PM   #5
I agree with what sdsester said,have you done this type of work before?,it looks pretty easy,but believe me it can be a challenge for a first timer.
Canarywood1 is offline   Reply With Quote
Old 08-12-2012, 07:47 PM   #6
The bottom part is called a stool and the trim on the sides is called casing for future referance.
Sills are the outside part at the bottom of the window.
The directions you recived are dead on.
Use a quality 2-1/2" sash brush and quality paint from a real paint store so there's less brush marks.
Old 08-12-2012, 08:25 PM   #7
Thanks. It is the casing I'm considering replacing. I think it looks dated.
I have installed casing before upstairs in my home a few years ago and I do recall it being time consuming.
Old 08-12-2012, 08:53 PM   #8
Looks like someone for some reason used beaded moulding not colonial mouding. It's not dated it's just the wrong moulding for a window.
http://howelumber.com/images/moulding_casing.gif
You can buy colonial moulding already primed in pine and MDF.
Old 08-12-2012, 09:06 PM   #9
Funny, I've lived in this house for 14yrs and have always wondered about this casing. I have never seen it anywhere else. Now I know why .
Old 09-29-2012, 04:57 PM   #10
What grit sander do you recommend, 180?
Old 10-15-2012, 03:59 PM   #11
Since there's no clear coat on top of the stained wood could I get away with one coat of primer?
Old 10-15-2012, 04:27 PM   #12
Rubbin walls since'79
Brushjockey's Avatar
In any case you only need one coat of primer. Primers job is to grip to whatever is underneath ( and maybe solve a couple other problems too) , but it is not good at "coverage". Your quality finish paint will do that better. Plan on at least 2 top coats. Fill holes and caulk after primer.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
tate16t (10-15-2012)
Old 10-15-2012, 06:03 PM   #13
paper hanger and painter
chrisn's Avatar
All you ever need, ever, on anything.
Old 10-22-2012, 09:03 PM   #14
Thanks all. I completed painting the bay window and like how it came out, thanks to you all. I will post pics soon.
What moulding parts do I need to create this craftman style trim.....
http://www.google.com/imgres?q=craft...w=1280&bih=685
Old 10-22-2012, 09:17 PM   #15
Bull nose
1 X 6 clear pine or MDF
The top could be any number of differant trims.
Cove, crown, base cap ECT.
http://pondershollow.com/pages/bulln...mouldings.html
http://www.tiloindustries.com/profil..._profiles.html
tate16t (10-22-2012)
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
New replacement window problems iminaquagmire Windows and Doors 7 11-12-2011 12:56 AM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 10:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
