Window Sill Varnish - Painting - DIY Chatroom Home Improvement Forum
Old 06-18-2008, 02:30 PM   #1
Another DIY Zombie
Rewards Points: 264
Window Sill Varnish
I have a large bow window that has a wood sill that is varnished and is in bad need of refinishing. The existing varnish is flaking off. My plan is sand this down to bare wood, then refinish. Any thoughts on a good wood varnish (poly) for this application? I have had good results in the past with Minwax products.
javan is offline   Reply With Quote
Old 06-18-2008, 02:58 PM   #2
47_47's Avatar
Rewards Points: 90
I'd use a poly or spar varnish, but I'm no pro.
47_47 is offline   Reply With Quote
Old 06-18-2008, 08:50 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
I would recommend a urethane over a varnish
The problem with windows and doors is the need something that expands and contracts
Varnishes (even marine) don't have the give and take and they tend to flake off
My first choice would be Sikkens Door & Window
A close second, the MinWax Spar Urethane
slickshift is offline   Reply With Quote
Old 06-19-2008, 04:25 AM   #4
I have used this product a time or two. McCloskey Man O War Spar Varnish.Here is a link.
http://myaccount.valspar.com/val/resident/manowar.jsp
mark942 is offline   Reply With Quote
strange brown spot on window sill ugabulldog Building & Construction 9 05-18-2008 08:38 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
Leaky window (sill) sable General DIY Discussions 5 10-08-2007 10:50 AM
Window Sill flashing? sandyman720 Building & Construction 6 08-06-2007 09:24 PM
Replacing the Sill on a Double hung Window Marshall Building & Construction 2 03-29-2007 11:18 PM
