Window Glazing Question - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-02-2010, 07:53 AM   #16
ccarlisle's Avatar
We've had good results with DAP '33" linseed oil-based putty for the exterior, when we've had to reglaze over new wood. Now my teacher used to use boiled linseed oil as a primer as his theory was that the linseed oil primer prevented the oils in the putty from being absorbed into the wood too fast. That's the way he was taught back in the 30's.
He didn't think much about using an alkyd primer over the bare wood instead as he didn't like a film layer between the wood and the putty; yet at least one preservation consultant I read seems to go along with the alkyd primer...maybe has more to do with the type of wood?
Anyway, priming one way or the other of new -or old -wood is always recommended. Good catch, chrisn...!
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 04-02-2010, 06:04 PM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
I would also use the linseed oil if you can still find it,I have had a gallon container for about 20 years now and still use it.
Old 04-02-2010, 09:12 PM   #18
jce
Chris
I would have to dbl check , but I believe your local SW store could get you some linseed oil through sher-source ordering program.
jce is offline   Reply With Quote
Old 04-04-2010, 09:31 PM   #19
Heritage Restoration
That glazing putty looks to be getting close to the end of it's life.
How I'd go after that would be:
Remove old glazing.
Remove Glass.
Clean glazing rabbet.
Brush good quality Boiled Linseed oil w/ maybe 10% turpentine in the rabbet. You could also heat the Linseed oil instead of the turps to get the pentration.
Let that cure overnight at least.
"Lightly" prime the rabbet with a good oil primer.
Bed layer putty, set glass, points, top layer putty. Use a good Linseed putty. Something like SARCO M or Dap "53" (Linseed based) in the USA. Not a fan of Dap "33" since it's Soya oil and Petroleum Oil based.
Let the putty Skin for at least a week.
Prime with same oil primer.
Paint as you like.
Never use anything that comes in a caulking tubes. It will give you nightmares later on down the road.
Skuce is offline   Reply With Quote
Old 04-05-2010, 06:19 AM   #20
chrisn's Avatar
Rewards Points: 122
Remove old glazing.
Remove Glass.
Paint as you like.
Good advise
Old 04-05-2010, 09:22 AM   #21
ccarlisle's Avatar
I just found it difficult to obtain less than 5-lb quantities of Sarco M putty, hence the 'DAP 33' choice - for our purpose which was small...
Again, I bow and defer to professional glaziers and restorers out there but IMO, I would see very little practical difference between a putty based solely on linseed oil and one based on soyabean oil+solvent especially when alkyd primers are involved. Traditionally and historically, yes, then linseed oil-based putties are the choice, but once you add a 'good alkyd primer' then automatically, you're into the "modern-day approach, aren't you?
I don't know enough about the advantages of modern-day putties vs. the linseed oil-based ones - if pushed I'd say both are equivalent - but the technicalities of using one or the other are way out of my league.
Very interesting thread however!
Old 04-08-2010, 07:19 AM   #22
ccarlisle's Avatar
Succinctly put, JMPainting...what, the thread blew you away, we're all full of it - or what?
Old 04-08-2010, 04:18 PM   #23
Rewards Points: 101
No, I posted my response before seeing the pic's of the windows , so my info no longer fit the situation.
JMDPainting is offline   Reply With Quote
Old 04-08-2010, 10:16 PM   #24
True enough.
If it was a full restoration. I would just soak the glazing rabbett in a protein-free mix of artist grade raw linseed oil, non-metal dryer boiled linseed oil and a small amount of turpentine.
Makes the oils stay in the putty instead of migrating out to fill the old, dry wood. If the oils leave the putty...you get it failing far too soon.
The primer is more of a redundant measure.
If you Don't do a linseed mix on the glazing rabbet...you MUST seal it. So the oil primer or shellac is imperative.
If you Do put on a linseed mix to saturate the wood...you can go either way.
Putting the linseed oil mixes on the raw wood with/without an oil primer is a good policy. It stops the wood from taking on water. It also makes the wood more similar to being "fresh wood" than the 60, 90, 150 year old wood that it actually is. It also acts as a minor stabilizer in the wood by refilling the cells.
The Practical difference between the putties is the drying/skinning schedule....which also dictates is overall lifespan.
True Restoration grade takes about 50-70 years to fully cure. You can leave it out on the table for weeks and it won't skin over enough to paint with Modern paints. The drying oils in it are so slow to oxidize that modern petroleum paints wrinkle the surface. They shrink when they dry.
So a historic Linseed Oil Paint has to be used. It will skin over the putty in a day. It also can be painted on the putty as soon as you lay it down!!!
Next you have the DAP 33 putty. It's a Soya oil based putty with a non-drying petroleum oil added to it. It takes forever to skin over (ie: about 4-6 weeks). It's nice to work with...but I don't like the idea of the added Petro Oils on my hands all the time. It also gets really sticky in hotter temperature in the summer.
DAP has also just recently changed thier putty formula. It used to be the awful mix that actually contained a CEMENT in it! You want a putty to be slightly flexible for years...not turn to concrete.
This new mix is better....but it hasn't been on the market long enough to see how it fails after 10,20, 40 etc years.
The DAP 53 or the Sarco M, Old Time Putty or LPL Putty/Mastic are all Linseed Oil based putties. They skin over in 1-2 weeks. So Painting with an alkyd primer is easy. Same with a water based primer. It will bite after a couple weeks no problem. It also bonds with the traditional Linseed paints (obviously. lol)
I'm going to stick with the Linseed putty in my business. I will use the restoration grade putty when I know I will be using a linseed paint on a very historic window. Otherwise, I'm going to stick with the linseed putty my Grandfather used to use ( I do have a small tub of DAP 33 in case of emergencies though ;-)
The Following User Says Thank You to Skuce For This Useful Post:
ccarlisle (04-09-2010)
Old 04-09-2010, 07:48 AM   #25
ccarlisle's Avatar
Very interesting! Are you saying, Skuce, that old putties never skinned over for 50-70 years? and if so, did they use linseed oil-based paint for that reason? i.e to keep it flexible? If so, why is old putty so hard to get off?
And, does that mean that old painted-with-linseed-oil-paints putties were somewhat flexible for most of their lifespans?
I had the idea that the clays in the old putties had something to do with moisture retention...a bit like they do in saltilo tiles... or adobe. Hmmm.
Old 04-09-2010, 11:12 AM   #26
Ok. Old putties did skin fairly soon. Especially if they had metal drying agents (japan dryer, etc) in the mix. The Skin then also acts as a barrier to prevent the core putty from oxidizing. Adding paint on it too helps keep the oxygen out that makes the oils harden.
The 50 years is the length of time that a high quality putty should stay flexible. Not the flexible in the sense that you think of like silicone caulk, or a car tire. The flexible in the sense of moving with the expansion and contraction of 2 dissimilar materials (wood & glass) during temperature changes.
So yes. It should be flexible in that sense for years and years and years.
There is a neat little trick here.
If you paint your linseed putty in a linseed paint, you can do something very, very cool. (Alkyd and Latex/Acrylic paints can't do this)
Every 5-7 years go over all the putty with an artist grade, boiled linseed oil. It basically renews the oils in the putty to near-new condition. So your putty should last you 300 years+ if this schedule is kept up. There are plenty of examples in Europe and a few in New England of original putty still being on windows that is over 250 years. All because of the scary word "Maintenance".
Same goes for traditional Linseed Oil paints. Re-coat every 5-7 years with an artist grade linseed oil and you will never have to repaint in your lifetime...and probably not in your kids lifetime either.
Also...it isn't a Clay that is in putty. It's Chalk/Calcium Carbonate powder.
When you see putty that is failing. It's probably because it's had Zero maintenance done to it since it was put on. So the putty has completely oxidized, gone hard. It also has probably had the paint finally fail on it so the water has gotten in and washing away hardened oil and chalk powder. When you actually think about it, it's pretty amazing how well it does perform with that kind of negligence for decades and environmental abuse.
Keeping up the 5-7 years treatment of linseed oil on the putty. No reason whatsoever that it won't last centuries.
Try getting that kind of performance out of some goop in a caulking tube!
Old 04-09-2010, 11:18 AM   #27
ccarlisle's Avatar
Oh, OK then I stand corrected on a number of fronts. Thanks Skuce...
Do you see a lot of linseed oils paint jobs in Ontario? Not necessarily historical jobs, but just for thr long-term economics of them?
Old 04-09-2010, 11:41 AM   #28
Starting to see them here and there. Especially after the whole "Alkyd Paints are Evil" thing going around all the box stores.
Acrylic/Latex tech just hasn't caught up to where Oil paints have been for wear resistance and overall longevity.
It's funny. I'm restoring a set of windows right now from a 1937 house. Taking them down to the original wood and starting over.
The original paint that is on the very bottom is this nice Blue linseed paint. The 2nd layer looks like a very early 1/2 linseed 1/2 Alkyd paint. All others are a typical Alkyd. The most modern is an exterior latex.
The Latex and Alkyds all are peeling and cracking and falling off. Takes nothing to strip them off. The very bottom layer of linseed paint will NOT come off at all. It looks like they repainted just for the fact that there was no maintenance done to the linseed paint and it literally wore out. No cracking, No peeling, Nothing. It's right into the wood. All the other paints that came after it are no where close to the original paints' durability.
The problem with modern paints is that they are simply plastic films that covers the surface . They do not penetrate to "root" into the substrate at all. They just skin the surface. That's fine and dandy till the first crack shows up.
Linseed paints go into the wood a LONG way. Sometimes up to 0.5" or farther. So it functions a part of the wood, instead of a sheet of plastic.
The term "Paint failure" is a very modern term. Over the last century we have gotten use to paint lifespans getting shorter and shorter. Now people are used to repainting every 4-6 years because of complete paint failure. A hundred years ago people were pissed off if they had to re-paint every 40-50 years!!
I can guarantee you there will be a resurgence in the use of Linseed paints in the next couple of years. I love the irony that it was 130 years ago that Linseed paint was the be-all and end-all. We're right back there again...cause it's simple...and it works!!!
Old 04-23-2010, 10:45 AM   #29
Bumping back up
Old 05-28-2015, 02:03 AM   #30
Rewards Points: 26
Sorry for necroposting everybody, but I feel it is warranted since the durability issue has come up...The Allback paints and putty started making their entrance in the US market about ten years ago. Skuce, can you report on their durability since you began their use? Thanks in advance
restorationdude is offline   Reply With Quote
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 08:44 AM
Bathroom Shower Window Replacement Question Jonnyonthespot Kitchen & Bath Remodeling 6 06-15-2009 12:54 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Another window installation question edwood79 Remodeling 3 11-15-2008 02:14 PM
Window Question? joan2020 Building & Construction 1 09-16-2006 07:11 PM
