Old 08-01-2009, 07:50 AM   #1
window glazing
I am currently removing old window glazing. My house is 90 years old and the glazing is stubborn. It takes an hour plus to remove the old glazing from each pane. Do I have to remove all the old glazing before application of the new?
Gatorgirl1 is offline   Reply With Quote
Old 08-01-2009, 11:09 AM   #2
Matthewt1970's Avatar
window glazing
Just remove the glaze that doesn't put up a good fight to stay in place. Then prime, re-glaze, and prime again. New Glaze will stick to old glaze with no problems.
Old 08-01-2009, 06:09 PM   #3
paper hanger and painter
chrisn's Avatar
window glazing
Be sure to OIL prime
chrisn is online now   Reply With Quote
Old 08-03-2009, 10:32 PM   #4
window glazing
Opps, I forgot that. Thanks Chris.
Old 08-04-2009, 04:22 AM   #5
chrisn's Avatar
window glazing
No problem.
Old 08-04-2009, 09:04 AM   #6
Haste Makes Waste
window glazing
I'll be doing this in next year or so....so from what I read, when reglazing windows, the primer and paint afterwards needs to be oil-based? There is oil paint there now, but I'd like to change it to latex.
saggdevil is offline   Reply With Quote
Old 08-04-2009, 03:12 PM   #7
chrisn's Avatar
window glazing
The bare wood needs to be oil primed for the galzing to stick to and not dry out. After the glazing drys for at least a couple days, it should also be oil primed, when that drys, paint with whatever.( except behr!) It is a long drawn out process, believe me,I have re-done my whole house, but after 85 years or so of paint buildup on the outside, it is amazing what a difference it makes to get rid of that buildup. My wife thinks it is the best thing I have ever done,( to the house, that is) or then again maybe not( only the house) maybe the best thing I have ever done period
Old 08-04-2009, 03:23 PM   #8
Haste Makes Waste
window glazing
LOL...thanks for the info, I'll keep it in mind for the outside projects; that is if I ever get the inside done. After some time at the beach I just can't seem to get back in the diy mode, lol. Anyway, my LR walls are VERY SMOOTH and look great; eventuallly I'll get the gardz and superpaint on the walls, lol. Fortunately I don't use the room much.
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
external window glazing geoffrey&bungle Building & Construction 1 01-08-2009 07:52 PM
Window Glazing - hairline cracks bill3752 Painting 3 10-04-2008 12:15 AM
PVC Window Glazing prowler 13 General Discussion 1 02-25-2008 05:56 PM
