Wind Blew Dirt On My Newly Stained Deck - Painting - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 11:00 AM   #1
Wind blew dirt on my newly stained deck
I have applied a coat of stain to a mahogany deck, and apparently the wind kicked up afterwards and blew sand and dirt on it. What's the best approach to address this. Does the whole job have to be redone?
joeblowofidaho is offline   Reply With Quote
Old 05-14-2013, 01:37 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
If the stain was a penetrating type that doesn't have much of a film ( like Olympic toner) you might get lucky. I wouldn't do anything till its completely dry, then you might use a blower and a broom to blow the dirt off for the most part.
Depends on the stain, oil stains that soak in a lot aren't usually very tacky when wet. but a latex or a oil solid stain? Could be a mess.
If you have to touch it up keep in mind that most deck stains can be over applied. And over applied stain always peels. Check the specs on the particular stain.
Jmayspaint is offline   Reply With Quote
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
Stained deck and it rained - some blotchy areas?!?! curls00 Painting 3 06-24-2008 04:18 PM
stained deck, problem with finish unitedwestand212 Painting 1 04-21-2008 08:43 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
