Will A Smooth Wall Show Up Through The Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-06-2014, 09:41 AM   #1
Rewards Points: 83
Will a smooth wall show up through the paint
had popcorn ceilings in my master bedroom that I just finished removing. I'm ready to mud and sand now so that I can paint. I need to remove the old corner tape where the ceiling meets the wall and place new tape for a nice seamless corner but the walls are textured. Is the method for mudding the same when the wall is textured as when it's smooth? I don't want the difference to show in the paint.
ttwin is offline   Reply With Quote
Old 04-06-2014, 09:45 AM   #2
Rewards Points: 144
No.The method is not the same.You will need to remove some of the teture on the wall to get a nice corner joint and then match the texture you have removed.What type of texture is it?
mako1 is offline   Reply With Quote
Old 04-06-2014, 09:46 AM   #3
Gymschu's Avatar
Rewards Points: 1,022
Same method but for your final coat, you have to find a match for the texture and mix up some thinned down mud to do a texture treatment on those corners. It's tricky because everyone does texture a little bit different.
They make rattle cans of texture that you can find at the big box stores, but since you may have a lot of texture to do, this could get pricey.
Old 04-06-2014, 10:36 AM   #4
Rewards Points: 83
It's an orange peel texture
Old 04-06-2014, 03:58 PM   #5
Rewards Points: 6,034
Mods could you merge the treads the same one is in drywall.
Old 04-06-2014, 09:24 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
I would think about crown molding at this point. I used the smaller 2" stuff in my house. It isn't that expensive, it will end up saving you time doing the wall/ceiling joint, it will look nice and add value to your house.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-07-2014, 10:55 AM   #7
Rewards Points: 83
thanks
Old 04-07-2014, 06:44 PM   #8
If you go to the Depot they have that crown in contractors packs for half the cost. May be more than you need but could still cost you less.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 09:16 AM
How to smooth off paint edge? konsole Painting 8 10-19-2010 05:36 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
