Will HD Rental Pressure Washer Be Strong Enuff ... - Painting - DIY Chatroom Home Improvement Forum
Old 12-23-2008, 03:32 PM   #1
Rewards Points: 1,062
Question
will HD rental pressure washer be strong enuff ...
to strip old paint off of an interior brick wall? i am trying to restore the original look and feel of the bricks and have them exposed in my living room.
thanks,
- a -
Old 12-23-2008, 04:24 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Probably not
There's a chance, I suppose
But really the only way I know to do what you want is a water/media blasting
And that's not a DIY project
slickshift is offline   Reply With Quote
Old 12-23-2008, 10:54 PM   #3
General Contractor
The pressure washer will most likely remove only the paint that is already loose. As slickshif stated water/media blast would work but it's definitely not a DIY process. I've had good luck removing paint from old brick walls using Peel Away it did a good job and only left a few small areas that needed to be detailed by hand.
jensenconstruction is offline   Reply With Quote
Old 12-29-2008, 09:21 PM   #4
you'll have quite a mess on your hands thats for sure.
there are some other posts around here about chemical stripping.
I was able to get paint off concrete with a pressure washer from a local tool rental store. Depending on the nozzle you can do quite a bit of damage to different materials. Next time I think about needing one, I wont hesitate to get one of those gas powered guys. They are very quick, you will know right away if its working and you can pressure wash a house in just a couple hours.
sunthas is offline   Reply With Quote
Pressure washer advice mntentman Tools 1 09-03-2008 08:36 PM
excell pressure washer help ericsloan Tools 1 06-14-2008 02:39 PM
Pressure Washer cibula11 Tools 6 04-26-2008 07:20 AM
Pressure Washer Question DIYchick Tools 8 02-05-2008 05:44 PM
