Why Is Wood Always Grainy/not Smooth After I Paint/coat It? - Painting - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 08:15 PM   #1
Why is wood always grainy/not smooth after I paint/coat it?
I'm new to painting wood, although I have some experience painting walls.
I like to use white wood/metal paint or just simple glaze to give the wood a deeper color and sheen.
But no matter how much I sand it (with my Bosch professional sander), then wipe and wash it under water..
After I paint, once it's dry, it's always extremely grainy and no longer smooth.
If anyone could help me with this, I would appreciate it very much!
Track is offline   Reply With Quote
Old 06-12-2011, 08:47 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
If you are using a water based latex paint the water in the paint will raise the grain. Some woods, such as southern yellow pine, will raise grain more than others. switch to an oil based paint and use a good primer also. After the 1st coat a light sanding with 220 grit sand paper will also help.
Millertyme is offline   Reply With Quote
Old 06-12-2011, 09:02 PM   #3
Too Short? Cut it Again!
It does sound like you are trying to skip the primer. This is especially important for new wood. I like solvent based alkyd primers designed as enamel underlays. You can paint either oil or latex finishes over them.
Old 06-13-2011, 03:19 AM   #4
Hah.
What is this "primer"? I'm not aware of it.
Old 06-13-2011, 04:19 AM   #5
Originally Posted by Track View Post
Hah.
Primer has the sole purposes, in this case, of sealing the wood, blocking stains from knots, etc. and bonding a nice uniform layer of film to the surface. This film, especially if something like an enamel underlay, evens out the wood surfaces and provides something the paint will adhere too perfectly.
Typically, a professional paint job consists of a coat of primer and two coats of finish.
I like solvent based alkyd primers for new wood but their are latex primers that work just as well. You cannot usually put oil based finishes over latex primers though. You can put either oil or latex over alkyd.
Old 06-13-2011, 05:14 AM   #6
No, I'm definitely using latex paint, which I guess you could call my 'finish'.
Could you link me to a 'primer'? I'm having small difficulty finding some. Do they come in different colors, or is it like silicone?
Old 06-13-2011, 05:19 AM   #7
I figure I'll be the first, surprisingly, to ask the question, in a loud voice, Why are you washing wood under water?
Old 06-13-2011, 05:30 AM   #8
I can't think of a better way to remove the saw-dust left on it.
Old 06-13-2011, 05:32 AM   #9
the Musigician
DangerMouse's Avatar
I use water to raise the grain for final sanding, but MY question would have to be: Why aren't you using a filler if you have heavily grained wood? (oak, for instance) Fill, sand and paint and you'll have a glassy finish!
DM
Old 06-13-2011, 05:35 AM   #10
the Musigician
They have this MARVELOUS new invention now called a "vacuum cleaner"!
DM
Old 06-13-2011, 11:58 AM   #11
WindowTreatment Installer
I wouldn't run water over the wood to remove sawdust. That definitly will raise the grain. A vacum like DangerMouse suggested to get the majority off then wipe the wood with a tack cloth. You can find them in any paint dept. A good sealer is important. Go to your local paint store ( not home center) and ask for a good latex sealer for wood. After priming you could go over it with some fine steel wool 000. This will help smooth out the grain that the sealer raised. Then paint.
bobtheblindguy is offline   Reply With Quote
Old 06-13-2011, 06:34 PM   #12
DM
I'm confused as to what a "filler" is.
I hear the words "sealer", "filler", "primer", "varnish", and I just don't know how to make heads or tails of it.
DM
You know, you don't have to use sarcasm. I understand your message perfectly, I swear.
I just didn't think that a cloth could remove 100% of the tiny wood particles, where as water always could. I did not think of the fact that it could raise the grain from inside the wood..
I don't know what would constitute a "local paint store" in Manhattan. I just go to Home Depot, and usually I find what I need.
Steel wool, huh? I have some, but never thought of using it.
Would it have the same effect of fine-grit sand paper?
Really, what I'm looking for, is leaving a wallpaper-smooth feel, almost plastic-like on my wood, using white paint.
Old 06-13-2011, 07:50 PM   #13
the Musigician
Dm
Old 06-13-2011, 08:22 PM   #14
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Ahh, Home Depot. Are you using Behr paint? If that's the case you can prime while you paint and paint while you prime!
I don't have any experience with that paint but I think the others can outline some of their experiences.
To brush off saw dust I usually just use a brush. A vacuum will work good too (probably better).
Old 06-13-2011, 08:40 PM   #15
the Musigician
Sorry about the sarcasm. Google paste wood filler. Follow the directions and it'll be smooth as glass.
DM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 06:29 PM
Staining Wood - When to use wood filler markronz Carpentry 8 03-04-2010 07:15 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
