Why Is My Paint Turning Yellow? - Painting - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 12:21 PM   #1
Why is my paint turning yellow?
Hello,
I recently started to finish a room in my basement. The room is warm and humid just due to where it is and the weather we've been having. It's often in the high 80's and 50% humidity. The areas where the drywall joints are, are turning yellow. The walls were all primed and then painted using bathroom paint. The actual joints seem fine, the parts that are yellowing are where the drywall compound was feathered out. this room was painted about 3 weeks ago. I'm very upset!
At first I thought it was the humidity in the room, but now that I think more Iím not sure. Maybe itís the paint?!? Itís from Lowes, Valspar.
Any ideas? I can't believe it's mold or water damage, since the room is only 3 weeks old. Any ideas??
Sorry, I know it's not easy to see on the photos.
Rickyrre is offline   Reply With Quote
Old 08-04-2013, 12:23 PM   #2
cdaniels's Avatar
Looks like something is bleeding through.Prime with a stainblocking oil primer and repaint you should be fine.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following 2 Users Say Thank You to cdaniels For This Useful Post:
Jmayspaint (08-05-2013), ToolSeeker (08-04-2013)
Old 08-04-2013, 12:25 PM   #3
It's fresh drywall though, what could be bleeding through? This is a brand new room. New studs, new drywall.
Old 08-04-2013, 01:00 PM   #4
cdaniels's Avatar
Maybe the mud was too wet I really don't know but it is stained.Stain killer and paint is the only way to fix it.
Old 08-04-2013, 01:40 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
I have seen some strange things bleed through on new jobs but it is usually where the actual wallboard is, not the joint compound. I think cdaniels is right on the mark.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 08-04-2013, 03:43 PM   #6
Gymschu's Avatar
Rewards Points: 846
Lots of questions here.......what type/brand of primer did you use on the drywall. Lots of cheap stuff out there with all kinds of fillers that MAY have caused this problem. Check the lot number of your drywall. Many times there is a recall on drywall especially drywall made over seas. You may want to ask your drywaller a few questions as well. Not uncommon for them to add something to the mud to make it more workable. This may have reacted with your paint. Just a few things to add to the discussion.
Old 08-04-2013, 08:31 PM   #7
Rewards Points: 4,796
It's hard to tell - do the areas lineup with where the joint compound was, or not? If so, it could be bad joint compound - either got stained with something, or went bad but still got used. Then that is bleeding through.
jeffnc is offline   Reply With Quote
Old 08-04-2013, 08:40 PM   #8
Davejss's Avatar
Rewards Points: 772
If you use a good oil based primer and finsh with two coats of acrylic latex that yellowish bleed through won't happen.
That's either a case of no primer, cheap water based primer, or even worse, a combo primer/paint.
Davejss is offline   Reply With Quote
Old 08-05-2013, 09:11 PM   #9
Painting Contractor CT
Rewards Points: 77
Post
Zinsser oil based primer should take care of it. Good Luck!
KD PAINTING is offline   Reply With Quote
Old 08-05-2013, 09:54 PM   #10
Jmayspaint's Avatar
Rewards Points: 534
That's really unusual. It happens though. Somehow moisture soaked into something, the wallboard or the primer, enough to create a water stain.
Cdaniels fix is probably the only one.
Jmayspaint is offline   Reply With Quote
Lead Paint Follow-Up RoughDraft Painting 24 06-18-2013 07:31 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Why has my white paint work turned yellow S. Alton Painting 6 07-07-2011 11:52 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
