Why Am I Getting Brush Strokes? - Painting - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 03:35 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Why am I getting brush strokes?
I am painting some trim, and using latex paint in a pearl finish.
I am noticing brush strokes, even after it dries. It is not that bad but I can still see them.
How do I avoid this? I have good brushes and good paint, Benjamin Moore for trim in pearl finish.
Thank you
yummy mummy is offline   Reply With Quote
Old 03-20-2011, 05:04 PM   #2
Gymschu's Avatar
Rewards Points: 486
Best way to paint trim is by laying it flat. Then the paint levels out and most of the brush strokes disappear. However, you may be painting it while it's on the walls & you don't have that luxury. Perhaps laying it on too heavy? Nice long brush strokes after you have it on and then "laying off" does wonders. Could be a technique problem. I use Proclassic from SW and I do see hints of a brush stroke now and again, but, for the most part, they disappear as the paint levles off.
Old 03-20-2011, 05:12 PM   #3
Rewards Points: 256
Hey yummy,
Add some Flotrol to the enamel. Slows down the dry time and allows the enamel to flow out.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 03-20-2011, 05:38 PM   #4
Originally Posted by spraygunn View Post
Hey yummy,
The Following User Says Thank You to jsheridan For This Useful Post:
oh'mike (03-21-2011)
Old 03-20-2011, 06:49 PM   #5
Rewards Points: 256
Hey Joe,
I got the memo. Now if only my kids paid that much attention.
Best of Luck
Steve
The Following User Says Thank You to spraygunn For This Useful Post:
jsheridan (03-20-2011)
Old 03-20-2011, 10:09 PM   #6
Try Benjamin-Moore Advance line of alkyd latex paints. They flow out to a perfect finish.
Dusty1 is offline   Reply With Quote
Old 03-21-2011, 08:19 AM   #7
Coatings Nerd
Excellent product, and definitely something to keep in mind for future projects.
I agree with the above post about adding some floetrol. Start with 4oz per gallon, and dont exceed 8oz. Also, depending which room you are working in, if its cool outside, open some windows/doors to cool the room down. The colder temperature will slow the dry time down some and give you more time to work with it.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 03-21-2011, 09:34 AM   #8
Thanks everyone for your help. I think I may be putting too much paint on the brush and not working it well. I will try less paint.
I have never used Floetrol? Is it a clear product?
Old 03-21-2011, 09:40 AM   #9
DIY staff
Rewards Points: 7,174
Flotrol is clear (milky looking) and makes the paint easier to brush out.
It's the only thing I've found the will help with that thick glob called Behr Paint,---Good luck.
Old 03-21-2011, 01:54 PM   #10
Apply it once, back brush once or twice and move on.
StevenH is offline   Reply With Quote
The Following User Says Thank You to StevenH For This Useful Post:
ltd (03-21-2011)
Old 03-21-2011, 05:50 PM   #11
Rubbin walls since'79
Brushjockey's Avatar
Different opinion on flotrol- one I used XIM latex extender my flotrol bottle hasn't been touched.
Much better product. Like grease for your brush.
But generally with quality enamels ( behr isn't one of them) I like a splash of water and a splash of XIM-xtender.
Brushjockey is offline   Reply With Quote
Old 03-21-2011, 08:55 PM   #12
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Lay the paint on and back brush it once in the opposite direction from the direction you are working, that should leave the surface free of brush marks. All of this talk about flotrol. There really is no need to use an additive. I never use an additive in anything I paint by brush or spray and the surfaces come out without brush marks. You need quality paint, quality brush and the right technique.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Old 03-21-2011, 09:27 PM   #13
DIY staff
Originally Posted by housepaintingny View Post
Lay the paint on and back brush it once in the opposite direction from the direction you are working, that should leave the surface free of brush marks. You need quality paint, quality brush and the right technique.
Fine advice----overworking the paint is the #1 cause of brush strokes.
housepaintingny (03-22-2011)
Old 03-22-2011, 08:12 AM   #14
Why not just use small foam rollers or a sprayer. It would take the whole paint brush out of the equation. I have painted many trim pieces and doors with foam rollers and they have turned out with that sprayed on look instead of having brush strokes. Just a suggestion.
mike-g is offline   Reply With Quote
Old 03-23-2011, 12:29 PM   #15
Thanks for everyones advice. I have never used foam rollers, but I think I will try.
I might be working it too much, as suggested. What I did was put the paint on with the brush, and then brushed, brushed and more brushing.....lol, because I thought that you have to "spread" the paint to a think layer?
I am going to try today to not work it so much. I have a lot of trim to do in this house.
Would the foam roller not put too much paint on?
Tips on not getting brush strokes? StevenH Painting 28 09-14-2009 04:09 PM
Floetrol, water, paint - ratio? -to minimize brush strokes newbpainter Painting 4 04-06-2009 08:12 AM
Primer brush strokes newbpainter Painting 5 03-25-2009 06:28 PM
Cutting - in Illinois G.C. Painting 11 11-24-2008 03:04 PM
Smoothing old brush strokes Double D Painting 5 09-23-2008 09:20 AM
