Old 09-20-2009, 03:04 PM   #1
Whitewashing poly treated wood
I have an entire room where the ceiling is poly treated pine wood, gold stain. I would like to whitewash this and lighten it up in there. Is there a product or way to stain it white without stripping the poly off first?
Thanks!
madmaxx1 is offline   Reply With Quote
Old 09-23-2009, 09:34 PM   #2
sdsester's Avatar
The challenge will be getting it to stick since it is probably oil-based poly. You will need to sand or otherwise degloss the surface that is there. Then, you might try making a glaze with the density you want using poly and white. You should stick with oil for this I think if that is what is already on there.
sdsester is offline   Reply With Quote
Old 09-24-2009, 12:17 AM   #3
Painting Company, NY
housepaintingny's Avatar
White washing is usually done before polyurethaning, its a mixture of a color of paint of your choice, mixed with 25% water per gallon of paint, and flowtrol, then its brushed, rolled on, letting it sit for a couple of minutes, then ragging it off in one direction. You can also apply a base coat first of your color choice then apply another color over that using the whitewashing method. That will give you two different color. Then you would normally apply your polyurethane, because the pine is already polyed, its sealed and will not accept any paint, but if you wanted too you could sand it, scuffing it up, clean the surface, apply a bonding primer, then apply a top coat of paint, or you could use minwax polyshades which already has poly in it, polyshades will go over the existing poly, but I would still sand first and clean the surface.
housepaintingny is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 01:38 PM
