-   -   white streaks on paint/ drywall when touched (http://www.diychatroom.com/f4/white-streaks-paint-drywall-when-touched-91395/)
krauseconst 01-05-2011 01:10 PM
we are getting white streaks on these walls in this office building that was just built 4 months ago i cant figure out where its coming from. when you touch it it leaves a white streak on it. is it the paint even though we painted it with 3 different paints and it is on every wall, the drywall, lights, drywall mud, or something coming from somewhere else. Has anyone had this problem? please help! Thanks
krauseconst 01-05-2011 01:13 PM
it is orange, brown and cream paint
Gymschu 01-05-2011 01:28 PM
Krausconst, I posted this very same question last week about some Valspar paint. Homeowner wiped a few marks off of wall with a wet wash cloth and now there are white streaks/marks where he wiped. I've been a painter for 30 years & never really saw anything quite like this.
krauseconst 01-06-2011 02:03 PM
we used valspar primer but not paint is it looking like powder? is it only there when you wipe your hand across it? then we painted it with dif paint and same thing happend
If it was water-based paint it needs to cure for 30 days so if wiped with a wet cloth it will leave marks
Gymschu 01-06-2011 02:22 PM
Kraus, it almost looks like drywall dust mixed in with water, kinda faint yet when the light hits it, it looks awful. This wall was painted 6 months before the homeowner tried to wipe a few spots off the wall with water and a washcloth......no detergent or cleaner was used. It's a taupe color, and, unfortunately, it's on a hallway that gets lots of abuse/traffic so wiping it is what they have to do from time to time.
krauseconst 01-06-2011 08:27 PM
GYM, well we can only hope that someone else has some suggestions! I am going to test for mold tomorrow good luck 2 you
Faron79 01-06-2011 09:40 PM
What EXACT Brand/Sheen/ and quality-level were the actual paints used?
The primer used makes no difference for this kinda stuff.
Since it's new-construction, it's almost always drywall-dust and/or general construction-dust floatin' around.
Have the ventilation filters been changed??
Is there a central furnace that may need to checked as well??
Faron
Gymschu 01-07-2011 05:59 PM
Faron
In my case it was Valspar Satin (their premium version) painted on the walls over a Sherwin-Williams eggshell that was already on the wall. House is 17 years old.
chrisn 01-08-2011 04:55 AM
Cheap paint, bad results.
Gymschu 01-08-2011 03:42 PM
Chris, I agree that Valspar is not the best paint line, but for a lot of people spending $25 per gallon fits their budget better than $45 per gallon paint. Now, at the request of customers I have used Valspar with decent success. I have never seen this type of burnishing before on any of their paints. My suspicions are that the chalky base used to make the cheaper paints like Valspar show through when the surface is scuffed.
chrisn 01-08-2011 07:15 PM
[quote=Gymschu;565604]Chris, I agree that Valspar is not the best paint line, but for a lot of people spending $25 per gallon fits their budget better than $45 per gallon paint. Now, at the request of customers I have used Valspar with decent success. I have never seen this type of burnishing before on any of their paints. My suspicions are that the chalky base used to make the cheaper paints like Valspar show through when the surface is scuffed.[/quote]
That was sorta my point:wink:
M196 01-12-2011 03:11 PM
Burnishing
Burnishing is most common with flat paints, dark colors, and with paints containing less solids. The general cleaning method is to use a cellulose sponge and water, or some non-ammoniated detergent if desired. Any abrasive cloth or ammoniated cleaner can bruise the film. Hope that this helps.
OneCallJohn 01-13-2011 03:43 PM
Burnishing or chalking. I was told its best to use a very wet soft rag for lubrication and a couple drops of dish soap that does not have a hand softener etc in it in a gallon of warm water. With these paints the most you can usually get off is finger prints and dirt spots.
chrisn 01-14-2011 04:13 AM
See post #9:laughing:
ccarlisle 01-15-2011 10:32 AM
What's the difference between a $45/gallon can of paint and one that costs $25?
$20 of our time wasted in answering "what went wrong" questions...:eek:
