Old 02-05-2013, 07:47 PM   #1
White Stair Risers Paint ? ( 17 )
Here I come again.
About to Paint white risers.
I'm about to tackle my stair risers, waiting for my new oak treads to come in
So i'm toying with the idea of applying white formica to the risers before I add my new treads. I could be wrong but I think I could just wipe down the white formica covered risers when they get toe scuffs on them. I have the equipment to cut a sheet of formica.
Open for conversations here.
Deck Hand
deck hand is offline   Reply With Quote
Old 02-05-2013, 07:55 PM   #2
cdaniels's Avatar
It's a lot easier to repaint than to re cover with formica.You won't get the bright glossy white with formica you will with paint.Have you thought about what the formica will look like in a few years after the toe of shoes have been kicking it? I wouldn't do it.
Charlie Daniels painting and repair
cdaniels is online now   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
deck hand (02-05-2013)
Old 02-05-2013, 08:05 PM   #3
A good way to minimize scuffs is to topcoat the paint with a clear latex poly.
jsheridan is online now   Reply With Quote
The Following User Says Thank You to jsheridan For This Useful Post:
Old 02-05-2013, 09:22 PM   #4
What is latex Poly ? I tried to google it and came up dry ?
Is this a two part mixture ?
when I had a small Chip in my bathtub I bought a special very hard paint
Very expensive two part mixture.
I think it was $15.00 for a small amount.
Deck hand
Old 02-05-2013, 09:27 PM   #5
Deck hand
Ok I found it I was looking for a special new Paint. Sorry about that !
D/H
Old 02-05-2013, 09:47 PM   #6
I use an enamel, it's so hard even a sander has a hard time getting it off.
Old 02-05-2013, 11:12 PM   #7
STAFF
BigJim's Avatar
There is a good chance your stairs could squeak if you use HPL on your risers. The riser goes behind the tread and glues and nails or screws to the back of the tread. You won't be able to glue with HPL and chances are there will be some movement of the treads which will rub the HPL and squeak.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
deck hand (02-06-2013)
Paint a white plastic flu / rubber surround - black etaf Painting 2 08-02-2012 08:23 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Should I paint existing riser white or cover it? metador Painting 4 09-22-2010 12:55 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
