White Rubbery Layer Between Wall Paper Layers - Painting - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 10:12 PM   #1
White Rubbery Layer between Wall paper layers
I'm remodeling my kitchen and am now in the wall paper removal stage.
The wall paper came off quickly; however, I didn't realize that there was another layer of wall paper underneath it! This wallpaper has a white coat on top of it, so I'm assuming the prior owners primed over it before they put up new wallpaper.
Upon closer inspection, the white coat is peeling in one small area. When I peeled it, it came off easily but was very rubbery. Is this rubbery white stuff oil based primer or leftover glue from the top coat of wallpaper? What should be my next step?
Thanks for any input!
tlptak is offline   Reply With Quote
Old 06-28-2012, 03:17 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Hard to say, but what ever it is needs to be removed
Old 06-28-2012, 08:55 AM   #3
Rewards Points: 394
It may be the backing for prepasted vinyl wallcovering , which allows the first layer to be peeled off. It could also be wall liner, which was used over the wall, or as an intermediate layer. Either way, it needs to be removed.
Will22 is offline   Reply With Quote
White dusty spots on dark blue wall!!!!!!!!! Patsfan34 Painting 41 05-26-2015 05:41 PM
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 09:16 AM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 08:22 AM
painted concrete under the wall paper? guygood Painting 3 11-30-2007 11:57 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
