White Powder On Walls - Painting - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 09:03 AM   #1
White powder on walls
In the bedroom I have white powder on the walls, I cleaned the walls and it appears again, is that mold ?
raluca1 is offline   Reply With Quote
Old 08-24-2010, 09:10 AM   #2
Enough is Enough
H. A. S.'s Avatar
Could be, there's a 'Whole jar Full', of molds.
H. A. S. is offline   Reply With Quote
Old 08-24-2010, 09:24 AM   #3
How can I treat that ?
Old 08-24-2010, 06:26 PM   #4
jules4's Avatar
It sounds like chalking:
PROBLEM
Chalking is the formation of fine powder on the surface of the paint film due to weathering. Chalking can cause color fading. All paints chalk to some degree, it is a normal, desirable way for the paint film to wear away and provide a good surface for future repainting. . . .
POSSIBLE CAUSES
Extended exposure to the combined effects of moisture and the ultraviolet rays of the sun.
Using a low-grade paint. Overthinning the paint. Overspreading the paint. Not priming and sealing a porous surface.
Problems and Solutions: Chalking Paint
jules4 is offline   Reply With Quote
Old 08-24-2010, 11:10 PM   #5
Rewards Points: 526
Interior paints are not supposed to chalk, just exterior ones. It might be that the room in question was finish coated with exterior paint. The description sounds a lot more like chalking to me than mold.
Windows is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
White powder on block foundation walls. lscott Building & Construction 2 05-18-2010 08:32 PM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 09:48 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Finishing my garage walls sk72 Painting 1 05-14-2008 08:21 PM
