White Paint Turning Yellow - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 10:14 AM   #31
Rewards Points: 121
Here's a few pics!
Originally Posted by Brushjockey View Post
Actually sounds cool to a paint junky. Keep us informed ( with pics!) of your progress!
white paint turning yellow-diy-pic1.jpg   white paint turning yellow-diy-pic2.jpg   white paint turning yellow-diy-pic3.jpg
JamesRW is offline   Reply With Quote
Old 07-22-2012, 10:22 AM   #32
Rewards Points: 121
Ha ha!
Originally Posted by chrisn View Post
You need to increase the size of the doorways that a football player lived in?
How big are you
you like a sumo wrestler?
Good question!! It's a wonderful classic home - built mid-century with great bones! That being said - the doorways were "small" (28" bath, etc.). Don't know WHY the last owners skipped those "details" in their updates, but whatever! They did install ALL new windows (with a 20 yr. transferable warranty) and numerous other very pricey changes!
We are loving the challenge - and the views!
Old 07-22-2012, 10:47 AM   #33
Rubbin walls since'79
Brushjockey's Avatar
Minnetonka?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-22-2012, 10:58 AM   #34
Rewards Points: 121
No, much smaller lake!
Minnetonka?
No, up north "a bit"! Just far enough out of the metro!
Old 07-22-2012, 04:45 PM   #35
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
Originally Posted by JamesRW View Post
Don't let OSHA see that second pic
chrisn is online now   Reply With Quote
Old 10-02-2012, 09:22 PM   #36
Rewards Points: 121
Ongoing project!!..
Minnetonka?
To Brushjockey: I see you are online right now - need some expert advice if you please...
We are pluggin' away at our project (slowly!). Right now we're are trying to perfect HLVP spraying for doors and trim. Primer went very well today and the first coat of painting did also. But on the 2nd coat of paint we had numerous runs appear (did not seem to notice them until AFTER the spraying was done.)
Primer is 123 thinned at 10%, then doors sanded down before finish.
Finish coat is Muralo Satin, thinned at the company's recommended rate of 1/2 pint per gallon (with water). I think for the next set of doors we will back off the water some.
In the meantime, what is the BEST way to fix the places that have runs?
Old 10-02-2012, 09:43 PM   #37
Depends how bad. Because they are fresh, they will probably be soft.
I would carefully carve off as much as you can with a sharp putty knife, sand down what is left. If that is still noticeable I would spackle that with Elmers wood filler, sand and reprime the spot.
Try lighter coats. That is the whole trick of spraying- enough but not too much.
Keep equal distance from door for whole pass. Start before- end after.
follow through.
Old 10-02-2012, 10:24 PM   #38
Rewards Points: 121
Thanks!
Great - thanks! I also read that you can try to rub out the run with a clean rag and denatured alcohol...are you familiar with that method?
Old 10-02-2012, 10:33 PM   #39
Ya- Denatured is a solvent for latex, might be worth a try.
I find solvent fixes often make a mess of the surrounding area too - I guess finesse is the key.
Just took some runs out of a clients paint job using the above method.
The Following User Says Thank You to Brushjockey For This Useful Post:
JamesRW (10-02-2012)
Old 11-13-2012, 01:06 AM   #40
Rewards Points: 121
We have FINALLY finished all the painting on this level of our project!
Thanks for everyone's advice and patience!
I have written a detailed account of our trial and error with the HVLP - hope it is helpful to someone.
Carpet goes in next week, and then I will put up a couple more pics.
Old 11-13-2012, 09:09 PM   #41
Painting Contractor CT
Rewards Points: 77
Post
Oil based paint tends to turn yellow after a certain time depending on what product you use. Also, when certain areas of the painted surface do not receive light they may turn yellow. Try to use superior quality paints that are specially formulated to prevent yellowing.
Good Luck!
http://www.kdpaintingct.com
KD PAINTING is offline   Reply With Quote
Newbie needs some painting advice bji Painting 8 12-26-2008 12:50 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Taking paint OFF the ceiling! anniegoff Painting 3 04-16-2007 04:09 PM
White paint help irlizard Painting 5 07-20-2006 04:14 PM
