White Paint Turning Yellow - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 08:18 PM   #16
Tom Struble's Avatar
Rewards Points: 2,002
Tom Struble is offline   Reply With Quote
Old 07-06-2012, 09:44 PM   #17
Workaholic's Avatar
Rewards Points: 268
I nailed this thread five years ago. lol.
Sean
Workaholic is offline   Reply With Quote
Old 07-21-2012, 02:05 PM   #18
Rewards Points: 121
Cleaning before painting trim?
Reading through this thread, and just wanted to clarify:
We have ALOT of trim to repaint in a whole house remodel project.
Here's what I'm doing:
1.)Trim has been taken down.
2.) Loosen dirt with a steamer
3.) Wipe off 2X with a strong ammonia & water solution
4.) Wipe off with plain water
5.) Prime with Gripper
6.)Finish with 2 coats satin Muralo waterborne (airless sprayer)
Will the ammonia solution cause any problems?
Do we need to sand between the primer & 1st coat or between the 1st and 2nd coat of Muralo?
Thanks!!
JamesRW is offline   Reply With Quote
Old 07-21-2012, 04:50 PM   #19
Too Short? Cut it Again!
It used to be that oil finishes gave a superior finish to waterbased enamels but I am not sure any more. 100 percent acrylics will certainly hold their color and would certainly be an answer to the inside of closets even if you wanted to stick with oil on trim elsewhere.
I used less and less oil toward the end. I would clean and scruff oil finishes, apply an alkyd primer/underlay and then finish with nice quality acrylic semi-gloss. I added Floetrol and believe I achieved the same surface as I could with oil. Of course you have to work a little faster with acrylics but with practice that is no biggy.
Old 07-21-2012, 04:57 PM   #20
Originally Posted by 0'mike View Post
Grand pappy always said when putting on underwear remember "Yellow in the front Brown in the back"
Unless you wear the same pair for a number of days in a row. Then you want to alternate between front and back and inside out for a full four days before spraying with Febreeze. You should not have to wash 100 percent cotton underwear more than once every month or so.
Old 07-21-2012, 05:05 PM   #21
Rubbin walls since'79
Brushjockey's Avatar
nm...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-21-2012, 05:08 PM   #22
nm...
Old 07-21-2012, 05:16 PM   #23
nm....
Old 07-21-2012, 05:39 PM   #24
Rewards Points: 121
I'm Lost!?!
Thanks!!
I'm thinking my question has gotten lost in the "on-going discussion" - I appreciate any help or feedback...thanks!
Old 07-21-2012, 05:52 PM   #25
Couple of Q's back-
why have you removed the trim?
There are better prep cleaners than ammonia- Krud Kutter, Soilex, TSP or TSP substitute.
Steamer? Wow- they must really be bad. Might cause problems with the wood.
Gripper and Muralo sounds fine.
The Following User Says Thank You to Brushjockey For This Useful Post:
JamesRW (07-21-2012)
Old 07-21-2012, 06:05 PM   #26
Rewards Points: 121
Originally Posted by Brushjockey View Post
Couple of Q's back-
Umm - yeah...house was a bank repo (former NFL player and too much partying - who knows what all was on the walls, trim, etc. I'm steam cleaning everything! But we love the house!)
Ok, I can use another cleaner, no problem.
Brushjockey, I see you are in MN - I should just hire you!!
Old 07-21-2012, 06:26 PM   #27
Im in S Mpls...
Also- Please answer why you removed the trim.. are you re rocking?
This will be a lot of work to get to refit right.
And one thing not on your list is a light scuff sand before priming- , but if you are reapplying the trim you will have nail holes to fill, caulking- all sorts of stuff.
Old 07-21-2012, 07:37 PM   #28
Rewards Points: 121
Overall...
We removed the trim for a number of reasons - renovated 1 huge bathroom into 2, so new sheetrock there etc., we are increasing the size of what doorways we can, so we need to recut alot of the base (shorter), casing, et al.
Some of the trim was "damaged" - but between the renovation and other changes, we have enough to match (some closet pieces will be used and replaced with a more simple moulding.)
This is just one floor of a 3 floor project - we may or may not remove it in other rooms. This is where we saw most of the "abuse and neglect", so there was considerable sheetrock repair done in all of the rooms as well. It seemed the trim was in the way in most places.
We are planning to fill all nail holes, etc. It's ALOT of work, but we have quite a bit of experience and time...
Old 07-21-2012, 08:01 PM   #29
Actually sounds cool to a paint junky. Keep us informed ( with pics!) of your progress!
Old 07-22-2012, 05:21 AM   #30
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
You need to increase the size of the doorways that a football player lived in?
How big are you
you like a sumo wrestler?
Newbie needs some painting advice bji Painting 8 12-26-2008 12:50 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Taking paint OFF the ceiling! anniegoff Painting 3 04-16-2007 04:09 PM
White paint help irlizard Painting 5 07-20-2006 04:14 PM
