White Paint Turning Yellow - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2007, 04:02 PM   #1
Question
white paint turning yellow
hello
A friend of mine has painted his interior doors white about one year ago.
Last week he sad that from a couple of doors one side turned yellow.
I went to have a look at it this morning and found out that 3 doors plus the frames have the problem. Al of them are doors that give acces to build in closets, and it is the "inside" of the door and frame thats turning yellow.
The paint he used is the same paint he used for the rest of the house, and the rest looks fine. Hot/ cold can't be the problem because he has central heating and an AC wich he uses. No moisture problems either.
I know that paint can change color due to sunlight, can the lack of sunlight be the problem??
Victor
victor is offline   Reply With Quote
Old 06-17-2007, 05:46 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Yup
Lack of sunlight will cause oil paints yellow
slickshift is offline   Reply With Quote
Old 06-18-2007, 04:15 PM   #3
Workaholic's Avatar
Rewards Points: 268
Yep i concur, Oil paint will yellow in dark places at a much quicker rate than where sunlight hits. I was in a house a couple of months ago that we ran oil in (stopped running oil a couple of years ago) and the trim looked great. Yet if i would of opened the closet door it no doubt would of been yellowed.
We used to have them shoot 2black at the paint store to slow the yellowing.
So closets, baths, anywhere that does not get sunlight will yellow.
Workaholic is offline   Reply With Quote
Old 06-19-2007, 12:38 PM   #4
Workaholic what do you meen by:
I live in Holland so english is not my first language.
Victor
Old 06-19-2007, 06:09 PM   #5
Workaholic's Avatar
Rewards Points: 268
I mean that we had the paintstore shoot a little bit of black in the bright white. It did not take from the color at all. 2black is just that. These days we are running manor hall high gloss waterborn, and we are going L2 which is 2shots of brown. It just gives it a bit more body to the paint for better coverage. Some bright whites tend to be a bit transparent.
The Following User Says Thank You to Workaholic For This Useful Post:
Tom Struble (07-06-2012)
Old 02-24-2008, 04:27 PM   #6
She'sapainter
its the tint that the paint store is putting in the paint to slow the yellowing
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Old 12-07-2010, 08:50 PM   #7
Rewards Points: 258
Hey SLM,
Good find. How did you come by that article?
Steve
www.handpaintedbysteve.com
spraygunn is offline   Reply With Quote
Old 07-06-2012, 04:54 PM   #8
Hi there,
I'm not certain abiut the sunlight and/or mix in the paint.
I painted my trim and doors on all of the bedrooms (bedroom, bath, closet) as well as halway closets. I noticed, the frame is not yellow but the door is. Any suggestions as of why aside from sunlight or paint?
Thanks in advance.
courtroom74 is offline   Reply With Quote
Old 07-06-2012, 05:21 PM   #9
Rubbin walls since'79
Brushjockey's Avatar
It is the paint. Bet it was an oil finish , right? I have had times that you couldn't touch up an oil enamel 3 months after applied- out of the same can.
It is the downside of oil , and one of the selling points of the newer "non- yellowing" waterbornes.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (10-03-2012)
Old 07-06-2012, 07:04 PM   #10
Well, the paint is new, yes and it's oil base. It's bright white and we painted over the old oil based paint on the door, door frame (jam) and baseboard trim. The only place turned yellow are the doors! So that is still the paint? If so, how do one mitigate the issue?
Old 07-06-2012, 07:42 PM   #11
Oil does that- some more than others. What exactly are you using?
I already gave the best answer- but now that you have it lets look at more info.
Old 07-06-2012, 07:49 PM   #12
Tom Struble's Avatar
Rewards Points: 2,002
in what post did you give the best answer?
Tom Struble is offline   Reply With Quote
Old 07-06-2012, 07:50 PM   #13
The one above the one that he re asked it..
Old 07-06-2012, 07:52 PM   #14
oh..i see
Old 07-06-2012, 07:55 PM   #15
Here- let me help-- waterbornes don't yellow...
Now?
Newbie needs some painting advice bji Painting 8 12-26-2008 12:50 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Taking paint OFF the ceiling! anniegoff Painting 3 04-16-2007 04:09 PM
White paint help irlizard Painting 5 07-20-2006 04:14 PM
