White Overspray On Brown Composite Roof - Painting - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 09:23 PM   #1
White overspray on brown composite roof
My painter sprayed the fascia boards today without adequate drop cloth protection on the roof. The paint went right over the top and left unfortunately very clear overspray on the brown composite shingle roof. What little paper he did put down (all of about 18" from edge) only served to create a very clear line in the overspray at the boarder.
Paint is SW duration, which I know to be very tenacious.
Painter is suggesting we try Krud kutter to remove, but I am cautious of using any chemicals and abrasive scrubbing, as I'm concerned this will further damage the roof.
Very upset as i've spent a few months prepping the house. Should've put the material up myself...But what's done is done.
Any thoughts on how best to handle this??
Thanks in advance for any suggestions.
-dgoth
dgoth is offline   Reply With Quote
Old 07-29-2013, 10:26 PM   #2
Gymschu's Avatar
Rewards Points: 490
Hope he is insured........he just bought you a new roof! There's no way that I know of that will remove the overspray without damaging the roof. I'm sure there are companies that specialize in this sort of thing so maybe your insurance company will contact them to see "where we go from here." Maybe since it's near the edge, a skilled roofer can replace only those affected by the overspray. Either way, this is gonna be a costly lesson for your painter.
Old 07-29-2013, 10:35 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
Flat brown spray paint.
Its too late to clean it up.
That's the kind of job that gives spray painting a bad name.
Overspray like that is totally unnecessary.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
oh'mike (07-30-2013), ToolSeeker (07-30-2013)
Old 07-29-2013, 10:57 PM   #4
Rewards Points: 386
-dgoth
Hiya dgoth...
Did you hire a painter? ...or were you just using the services of a painter friend? If you hired a painter (and paid him), you need to hold him accountable. He has insurance, he needs to make a claim. He is not a professional roofer, and given his statements about scrubbing the surface with Krud Kutter indicates he has no claim to expertise in roofing products either. At this point, the damage is simply aesthetics - no structural damage has been done to the roof. Improper cleaning products and any type of scrubbing on a composition roof though could lead to serious damage or a substantially diminished lifespan of the roof.
If this guy is a professional painter, he really doesn't sound like he's a very good painter...or at least not a very good spray painter. 18" paper should've been more than plenty of protection from "overspray" unless he was just really wild with his technique. Spraying homes can be tricky, and for a novice it'd be really easy to get spray on everything within range...that's why you hire a professional - so those things don't happen. And if they do happen, a professional has the means to resolve the problem....and if you did hire a professional painter, why were you doing the prep work?
Tell your hired painter to contact his insurance company....in the meantime, there are companies out there that specialize in cleaning composition roofs without damage to the roof. The do a great job on moss, mold/mildew, rust-staining etc. They may have a viable solution for you.
ric knows paint is offline   Reply With Quote
Old 07-29-2013, 10:58 PM   #5
Rewards Points: 6,652
Shingle paint will fix it.
Old 07-29-2013, 11:39 PM   #6
cdaniels's Avatar
I hope he was insured.Get some estimates from a roofer and file a claim.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 07-29-2013, 11:52 PM   #7
Thanks for all the quick replies and useful info.
I did hire a licensed professional painter, who surprisingly has a strong reputation in town. But unfortunately it was his "crew" that made the mistake, while he was off-site.
They just wrapped up the first day in what is supposed to be a 3-day job. No payments have been made yet.
I had originally planned on doing all the work myself, including painting, but after completing all the prep work found myself running short on time and very busy at work. In the interest of time, chose to hire a seemingly very good, and certainly not inexpensive, painter to wrap everything up.
I know he carries workers comp insurance, but not sure about liability. Is there an easy way to confirm this? Is this a requirement in California?
I'll call a roofer tomorrow to get a professional roofer opinion.
-dgoth
Old 07-30-2013, 06:25 AM   #8
DIY staff
Rewards Points: 7,174
Let the painter try 'dusting' the over spray with some assorted flat spray paint----I hate to admit it,but I have done that myself---and hid the over spray successfully using this method---
ToolSeeker (08-05-2013)
Old 07-30-2013, 06:38 AM   #9
kwikfishron's Avatar
Rewards Points: 194
You should be able to find some useful info here. http://www.cslb.ca.gov/Consumers/
kwikfishron is online now   Reply With Quote
Old 08-05-2013, 01:07 PM   #10
ready to roll's Avatar
This is why I hardly ever spray facia. I spray eves and siding and the trim is almost always done by hand.
ready to roll is offline   Reply With Quote
new "inspire" slate composite roof...(plastic) mozeppa Roofing/Siding 16 04-08-2014 03:47 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
I'm looking for White composite decking... Anyone? Lightning Remodeling 1 05-25-2009 05:48 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
