White From Old Alluminum Siding Stained Brick - Painting - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 04:09 PM   #1
The Big Builder
White from old alluminum Siding stained Brick
Hello everyone,
I have a brick house with the old white alluminum siding that is chalking. This chalking has dripped down the side of the house a little and made some of the brick white.
Please tell me how I may be able to remove this without ruining the brick. I have tried a high pressure washer and it didn't work so well. Is there a chemical or something I can use?
Stephen
bigbavarian is offline   Reply With Quote
Old 06-11-2009, 12:34 PM   #2
NAV
that is a common problem. unfortunately its not easy to remedy. there are chemicals that will work but they can discolor the brick.
what type of brick is it? color, texture? how old is it?
whatever the chemical product is that you use it will be acid based so your plants will have to be protected and some cleaners can etch glass so you have to protect the windows. you will also have to neutralize the acid after you clean the brick.
Look into Diedrich Technologies - they have some great products (always read all the specs when using anything)
the easier way out would be to have someone come over and sandblast the brick. it will cost you more but it will not damage the brick (possibly the mortar if your mortar is in bad shape) and your landscaping will live.
if you want a good job and to take the liability off of yourself hire a professional. Make sure they show you a similar job they completed before you let them proceed.
good luck
NAV is offline   Reply With Quote
Old 06-11-2009, 01:03 PM   #3
The Big Builder
Thank you for the advice.
It is a tanish kind of brick fron the 50s. Not exactly my favorite color.
Luckily this issue is only areas on the house where we don't have eves like the garage and teh ends of the house.
I will look into the different options you mentioned.
Thank You
Old 06-11-2009, 07:24 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
A water-media blasting is the only way I know that will get the bricks clean
It's not a DIY project
Contact some specialty companies for estimates
slickshift is offline   Reply With Quote
Old 06-12-2009, 12:19 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
ive never personally done it but ive seen muriatic acid used with good results
Tom Struble is offline   Reply With Quote
white trim vs. wood stained nwalford Interior Decorating 17 02-28-2011 03:54 AM
Siding and Brick veeneer wall? sandyman720 Building & Construction 9 08-13-2007 05:02 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
