White Oil-based Paint Yellowing? - Painting - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 05:57 AM   #1
White oil-based paint yellowing?
I was told at the paint store if I used white oil-based paint it would yellow. What makes it do that and do I really have to worry about it?
roeldred is offline   Reply With Quote
Old 02-27-2013, 06:52 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Lack of sunlight will cause oils to yellow. It depends on the exact composition of the paint as to how bad it will be but pretty much all oil does it. If you have it in a closet for instance where it gets no sun you will get much worse yellowing than you will in a wide open area with a lot of windows. Is there a reason you are using oil? Oil still has it's place but it's becoming far less common than it use to be. You can add just a touch of black tint to the paint to keep the yellowing to a minimum.
Darkling Designs
poppameth is offline   Reply With Quote
Old 02-27-2013, 06:58 AM   #3
Rewards Points: 12,790
That was my first question, why oil?
The new latex quality paints out there will last just as long and in some cases longer.
Far easyer to clean up at the end of the day with no hazardest chemicals.
Less VOC's.
Old 02-27-2013, 12:11 PM   #4
Rewards Points: 394
Alkyd resin in the product is the cause of yellowing, due to a lack of UV (sunlight).
Will22 is offline   Reply With Quote
Old 02-27-2013, 05:02 PM   #5
Gymschu's Avatar
Rewards Points: 170
This^^^^
Over the years I have seen oil-based paint go from a bright white to a nicotine yellow.......it takes a while for it to happen, but, it sure looks ugly compared to a bright white latex.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
cdaniels (02-27-2013)
Old 02-27-2013, 08:34 PM   #6
cdaniels's Avatar
Yes you do need to think about it.Get with the times man....lol.....with proper prep and priming you can convert your woodwork to a waterborne paint.It will stay whiter and modern acrylics are very durable.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-28-2013, 05:23 AM   #7
Thank you all, there is plenty of light, it is a metal handrail, but it sounds like the acrylic will work so that's what I will use.
Old 02-28-2013, 06:51 AM   #8
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If it's a metal handrail use an Acrylic DTM (direct-to-metal) paint. Most brands have one.
Darkling Designs
Painting tricky Basement walls. What paint should I use? tw1208 Painting 1 10-12-2012 09:07 PM
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
basic white paint mcl6302 Painting 6 10-11-2010 05:58 PM
Lead based paint jenikahula General DIY Discussions 3 03-10-2009 01:08 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
