When To Strip The Paint (instead Of Sanding It)! - Painting - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 06:43 PM   #1
Question
When to Strip the paint (instead of sanding it)!
I need to paint our trims, but they have been painted over and over again. I need advice on whether I should sand them or use chemical to strip them. If I should use chemicals, please leave some name brands and reasons why I should use those and not others. Thanks everyone.
shokufeyesib is offline   Reply With Quote
Old 10-12-2008, 07:03 PM   #2
I would strip the paint from the trim and then lightly sand it to receive the primer and new paint. Use an enamel paint for the trim.
http://www.diynetwork.com/diy/pt_str...2277249,00.htm
pattyg2 is offline   Reply With Quote
Old 10-16-2008, 08:31 PM   #3
Rewards Points: 160
Another option is to replace your trim. I know for me instead of having to make my old trim look good, I just replaced the 1x6 and 1x4 trim and it didn't cost me all that much.
My house was easy to do though, so it matters how much trim you'd have and what difficulty.
hellothere123 is offline   Reply With Quote
Old 10-16-2008, 08:58 PM   #4
Rewards Points: 506
Unless the existing coats are failing or providing a poor surface on which to paint, you can keep piling on as much paint as you want.
Unless the trim is historical, ornate, or otherwise expensive, replacing would be about a zillion times easier than stripping. Sanding to remove many layers of paint is more or less not an option.
SirWired
sirwired is offline   Reply With Quote
Old 10-22-2008, 08:50 PM   #5
well, the apt is a pre-war apt. I don't want to replace the trim, 'cause they are original. the paint is real bad. its peeling and cracking...painted over for many years. the house will look old and patched over if I don't clean the trim before I paint them again.
a couple of my friends said that I should use chemical paint strippers. it would be more effective. I just want to confirm that.
thanks.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
