When To Stain Pressure Treated Wood? - Painting - DIY Chatroom Home Improvement Forum
Old 09-30-2013, 01:33 AM   #1
Rewards Points: 170
Question
When to stain pressure treated wood?
I built a nice Pergola mid summer out of pressure treated wood. It seems to be dry now and I was considering putting a coat of stain (Either a darker color, or a clear) to help protect it for the winter and the future.
Has enough time passed if its only been completed for about 2 or 3 months? I thought I once read you are supposed to wait a full year, but it seems long and the wood looks like its dried out.
Is a clear stain ideal to help protect it from the winter, snow, rain, cold, etc?
Any tips appreciated.
HandyFrank is offline   Reply With Quote
Old 09-30-2013, 07:10 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
need a moisture meter to check for sure
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (09-30-2013)
Old 09-30-2013, 11:29 AM   #3
Rewards Points: 170
Didn't even think of that, good idea! I'm going to order one up and check it out.
Thanks.
Old 09-30-2013, 11:41 AM   #4
Jmayspaint's Avatar
Rewards Points: 534
You would do yourself a big favor to sand the floor before staining/sealing. Of at least wash it good.
People often make the mistake of thinking new wood does not require any prep. I learned the hard way years ago to get the most out of a stain job, the wood needs to be prepped even if its new.
If you get it right the first time, its so much easier to maintain long term.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (09-30-2013), ToolSeeker (09-30-2013)
Old 10-06-2013, 12:23 AM   #5
Rewards Points: 170
So I bought a cheap moisture meter and it reads between 13% and 18% depending where I probe and how close it is to the ground. I read that anything under 19% is acceptable to stain. Is that accurate?
Does it make sense to stain pressure treated with a clear coat to help protect if I don't want to put a color stain on it? If I want to stain it a color later can I do it 2 or 3 years down the road when the clear fades away and will it absorb the color then as it should?
Old 10-07-2013, 09:42 AM   #6
Jmayspaint's Avatar
Rewards Points: 534
Technically 18% or lower is ok for most stains. I like to get 14% or lower myself.
Most clear sealers are going to complicate using a solid stain in the future. Some more than others.
You might look into using 'Seasonite' its a product designed to protect new wood during the curing process and can be stained over in the future.
http://www.owatrol.com/pdf/technical-en-seasonite.pdf
Drying pressure treated wood Cooltools Painting 5 10-14-2011 10:46 AM
Green vs dark brown pressure treated wood acerunner Carpentry 5 02-22-2011 05:36 PM
Any way to flatten cupped pressure treated wood? spaceman spif Carpentry 13 07-31-2009 05:05 PM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 10:53 AM
