When Painting The Exterior... - Painting - DIY Chatroom Home Improvement Forum
Old 03-12-2014, 10:54 AM   #1
Rewards Points: 87
When painting the exterior...
When you're painting the outside of the house, what do you do to prepare the surface? I noticed my house has a lot of dirt and dust on the wood parts. Its a brick house so the actual wood and siding is somewhat minimal, but what is there is kind of dirty.
So what is the standard procedure for painting the outside of a house? Do most people just take a powerwasher to it, and call it good? Or do you get in there and scrub with a brush and dish soap first? Something tells me you don't want to just paint over all that surface dust and dirt.
Bennylava is offline   Reply With Quote
Old 03-12-2014, 11:23 AM   #2
Rewards Points: 12,856
Pressure wash and see how it looks.
It's useless trying to paint over the dirt.
Old 03-12-2014, 11:35 AM   #3
Jmayspaint's Avatar
Rewards Points: 534
The first thing I do is apply a bleach/water solution to kill any mildew then pressure wash.
Scrubbing is only necessary in certain situations such as oxidized paint or very heavy mildew.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
RiderS (04-01-2014)
Old 03-12-2014, 03:32 PM   #4
Rewards Points: 87
Thanks!
Old 03-12-2014, 04:05 PM   #5
Painting Contractor
Rewards Points: 85
If you have a lot of mildew, there is a product called Jomax that you can mix in your pump sprayer with your bleach water to activate it. It cleans like crazy. Just make sure you hose down your shrubs and plants before and after.
VAProPainter is offline   Reply With Quote
Old 03-12-2014, 05:36 PM   #6
Gymschu's Avatar
Rewards Points: 230
Be careful when washing your trim on a brick house. Sometimes certain cleaners can stain/discolor the brick if not thoroughly rinsed off the wood AND the brick. Usually not a problem but sometimes it comes back to bite you.
A/C on or off during exterior painting? Angelique Painting 16 10-14-2013 05:15 PM
what type of color should i use for painting the exterior of my house? TTpainting General DIY Discussions 2 10-07-2013 09:46 AM
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 08:56 PM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 07:52 PM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
