When To Change Paint Roller Sleeve - Painting - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 06:11 PM   #1
Haste Makes Waste
When to change paint roller sleeve
How long does a quality paint roller sleeve last and how do you know when it's worn out. I've painted four rooms and use a new roller for each room for the paint and one for each room for the primer. I throw them out after I finish the room. I am now working on three or four rooms of same color. How long can I continue using the same sleeve?
saggdevil is offline   Reply With Quote
Old 05-28-2009, 06:52 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 146
Depends on the quality of the cover and how well you clean them but I usually get a couple rooms worth before turning them over to primer covers for wallpaper primer.
Old 05-28-2009, 08:35 PM   #3
Rewards Points: 156
I worked with an older tradesman that told me years ago to wrap the roller in aluminum foil to help keep it from drying out. So after I use a roller I rinse it out if I think it will be several days until I use it again and wrap it tight in foil, otherwise if I might use the roller later that day I wont rinse it at all and just wrap it in foil. It seems to work well. Anyone else ever try using foil ?
creamaster is offline   Reply With Quote
Old 05-28-2009, 09:21 PM   #4
I've used plastic bags
Old 05-28-2009, 09:56 PM   #5
Rewards Points: 506
I usually do a couple of color coats with a roller, and then they get to apply primer, or if I did a really good job cleaning them out, ceiling paint. Life is too short to spend a lot of time cleaning out $5 roller covers.
SirWired
sirwired is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
