What's a good price to pay to Paint Kitchen cabinets
Kind of hard to say as a project like this is mostly labor, and labor can vary from region to region
Realistically, I'd expect to pay between $100 and $130 per unit for a quality paint job (bare cabs or a previously stained/poly'd re-paint) from a quality painting company
A "unit" would be kind of like what you'd think, a bottom cab with drawers or doors, top cab with doors...it's kind of obvious if you look closely at how they are put together
I would be suspicious of any quotes less than $100 a unit
As staining bare cabs would be much less labor, I can't see how staining would be more expensive, unless you also wanted them poly'd (which would be a good idea), but that should be about the same rather than (a lot) more money
(process = one coat stain, two coats poly vs. one coat primer, two coats enamel...not much difference)
Staining cabs that are already stained could be an issue, and could be much more expensive than painting if a lighter or incomparable stain color was desired
If you get 3 quotes, all for around $75 a unit, or all around $200 a unit, then obviously the labor in your area is pretty different
