What's Going On With My Primer?? - Painting - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 10:54 PM   #1
What's going on with my primer??
Picked up some new cabinet frames that had a finish on it. I'm changing them to a white satin, so I sanded down the surface, wiped it off and applied my primer. The primer dried and I'm getting some "holes" in the surface. Will this be a problem when I apply the top coat and second coat? Do I need to re-sand and re-apply the primer? Help, please.
starkhd is offline   Reply With Quote
Old 10-11-2011, 11:10 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
What primer?
Looks like it had something like a polish on it..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-11-2011, 11:52 PM   #3
Gymschu's Avatar
Rewards Points: 466
Looks like spots where the primer didn't bond to the cabinet surface. Are you using a quality bonding primer such as Zinsser's CoverStain? I would try to lightly sand those spotted areas again and then just apply some primer to the trouble spots to see if they will cover.
Gymschu is online now   Reply With Quote
Old 10-12-2011, 12:34 AM   #4
MikeKy55's Avatar
Rewards Points: 254
In the automotive world we refer to that as 'fish eye'. For auto paint there is a fish eye eliminator you add. Basically as I understood it, it was a chemical that was compatible with wax/grease etc. as well as the paint. I never liked using it because it reduced adhesion as well. When spraying auto paints the best way I found was to spray a very light coat on first and allow it to flash for awhile before applying the next coat.
Now that doesn't apply to your problem, but it is an example that will tell you the cabinet had either a little cooking grease or furniture polish that you didn't get off when prepping them for paint.
If it were me, I would scuff the areas lightly and spot prime them again. Don't load the paint on them, just a light coat and give it time to dry.
MikeKy55 is offline   Reply With Quote
Old 10-12-2011, 05:30 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Some kind of contaminate on there ( silicon, I would bet) It will not matter what primer or paint you use, it will not stick until it is removed.
The Following 2 Users Say Thank You to chrisn For This Useful Post:
1910NE (10-12-2011), DangerMouse (10-13-2011)
Old 10-12-2011, 07:08 AM   #6
Alrite. Thanks for the advice all.
Old 10-12-2011, 07:04 PM   #7
In addition to sanding, does anyone have a suggestion for a compound that might help in getting this contaminant removed?
Old 10-13-2011, 04:44 AM   #8
chrisn's Avatar
Rewards Points: 228
If it is silicon, dynamite or a flame thrower
The Following User Says Thank You to chrisn For This Useful Post:
Old 10-13-2011, 08:09 AM   #9
Stark, how widespread is this problem? I first thought it was rust, are they wood? I would wipe the area with a degreaser and try again, do a sample spot until you get it. Try thinner, dish soap/rinse, etc. It probably as Mikeky says is fish eye from grease.
Old 10-13-2011, 08:38 AM   #10
It's across several doors and yes they r wood cabinets. Thanks for the advice. I'll try some of the compounds u guys mentioned and see how I fare.
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 12:48 PM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 07:29 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
