What To Use For Covering Nail Holes - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2014, 01:40 PM   #1
jkk
Rewards Points: 233
What to use for covering nail holes
I need to fill in nail holes left from using nail gun on casing. What can I use to make these holes invisible after the casing is painted?
jkk is offline   Reply With Quote
Old 02-22-2014, 02:02 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
A good spackle like Dap Crackshot works well. Fill them completely and leave a little excess sticking out of the hole. When its dry sand flush.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (02-22-2014), ltd (02-22-2014)
Old 02-24-2014, 07:10 PM   #3
Dap 33 is the best. It's a window glazing putty. No need to be sanded after and application is one or two flicks of the finger
mcnic is offline   Reply With Quote
Old 02-24-2014, 07:40 PM   #4
Gymschu's Avatar
Rewards Points: 846
The problem with window glazing is that the oils in the putty will wick into the latex painted surface.
Gymschu is online now   Reply With Quote
Old 02-25-2014, 03:58 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
bad idea
Old 02-25-2014, 06:42 AM   #6
Painting Contractor
rbriggs82's Avatar
Right on Josh, just don't forget to sand!
rbriggs82 is offline   Reply With Quote
Old 02-25-2014, 07:31 AM   #7
Recently, I have been using Elmer's Wood Filler Max and been happy with it.
However, there's no escaping the sanding. This product can be sanded down in as little as 15 minutes. But I've found that waiting about hour produces better results. Good Luck.
DIYRemodeler is offline   Reply With Quote
Nail Shear Strength Test ddawg16 Building & Construction 32 08-24-2012 09:17 PM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
route wire through poorly drilled holes in joists? bottlerockett Electrical 4 06-27-2012 09:28 AM
Fixing nail holes traci3 Painting 1 08-26-2010 11:40 AM
Framing nail gun is blowing holes in my fence TheMac13 Building & Construction 4 06-28-2010 05:31 PM
