What Type Of Sheen Does Zinsser 1-2-3 Primer Bulls Eye Have? - Painting - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 01:43 AM   #1
Rewards Points: 237
Question
What type of sheen does Zinsser 1-2-3 Primer Bulls Eye have?
I primed this ceiling with Zinsser and I really like the way it looks just primed. It has a nice sheen. It's a little shiny but not too shiny. I'm guessing it's an eggshell or satin. I'm going to buy some paint and I would like to keep the same sheen that's on the ceiling now. Has anyone worked with the 1-2-3 primer and can you tell me what type of sheen it is or is close to? Thanks
Deck is offline   Reply With Quote
Old 06-08-2012, 02:26 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
I would guess somewhere between eggshell and satin, although I would not recommend ceilings be this sheen( unless it is the kitchen and or bath)
chrisn is online now   Reply With Quote
Old 06-11-2012, 09:49 PM   #3
Rewards Points: 237
Yup, you're right it must be somewhere between a satin and an eggshell. I went to Home Depot and I bought a gallon of Behr Premium Plus Ultra Interior - Ultra Pure White - 7750 - Satin paint, 678885070298. It cost $35. I should have bought it from their website because it looks like they sell the same thing for $31. I put a coat on the ceiling and it looks nice. The sheen is a little greater than the primer's sheen.
The paint was thinner than the Zinsser primer. I thought since this Behr paint was also a primer that it would be about the same. Maybe I'm just too used to the Zinsser stuff? The paint job came out good but under scrutiny there are two or three roller lines I can barely see but want to take care of, so I'm doing a second coat tomorrow. I thought it was thin stuff but I don't have much experience with paint.
For anyone who is going to use satin on a ceiling, bear in mind I put a lot of work in before I primed making sure the entire ceiling could be made smooth after using joint compound fanned out to hide the seams, bumps, dimples and imperfections. Then I sanded everything nice and smooth. The entire compound/sand/compound/sand process took a few hours a day for several days.
Old 06-12-2012, 02:46 AM   #4
I don't see the point in using wall paints on white ceilings. The idea behind specific ceiling paints is to be splatter resistant and create a super flat white surface to help with light deflection and avoid seeing imperfections. Basically, a white ceiling is made to avoid looking at the ceiling. If you're using wall paint, might as well pick a color for the ceiling.
pucks101 is offline   Reply With Quote
Tags
zinsser
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 09:06 AM
PVA Primer Disaster bobcatm Painting 1 08-17-2010 12:41 PM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 06:29 AM
what type of primer? markgardner Painting 1 06-26-2009 04:44 AM
What type of sheen to use interior hellothere123 Painting 3 04-20-2009 04:40 AM
