Old 06-25-2009, 10:23 PM   #1
what type of primer?
Hi all, I just scraped old popcorn off a ceiling. I'm ready to prime the ceiling before applying a stomped texture. I'm getting mixed advice over what primer to use. One guy said water based...another said that since there is some residue left on the ceiling from the old popcorn, I need an oil based primer to soak into the drywall and seal it because the water based primer might separate from the old joint compound...any thoughts?
markgardner is offline   Reply With Quote
Old 06-26-2009, 05:44 AM   #2
paper hanger and painter
chrisn's Avatar
Here is what I would use, unless there is a problem with staining, then I would use Bullseye 123.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Thoughts on using Exterior SW Duration as a primer. refreshrate Painting 7 06-09-2009 10:40 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
What type (if any) primer? Tmb9862 Painting 5 10-12-2006 11:14 PM
