What Is The Top Coat On This? - Painting - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 10:31 PM   #1
Question
What is the top coat on this?
I know that the paint color, type, brand etc is exactly the same but when I put it on it is 3 shades darker. I was told that there was a top coat over it. WHAT is the top coat though?
wfy3432 is offline   Reply With Quote
Old 08-25-2011, 10:42 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
And how do you think we would know?
Brushjockey is offline   Reply With Quote
Old 08-25-2011, 11:50 PM   #3
Learning by Doing
Leah Frances's Avatar
Looks like rickroll to me.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-26-2011, 04:57 AM   #4
m1951mm's Avatar
The two paints pictured are no where near close. Is the issue someone left some touchup paint marked for that particular room and you wanted to do touch up. What it looks like to me is that someone has come in and painted a whole different color. Many times when you buy a house the owner will do a quick " clean up the look" of the house with a coat of off white paint. Then leave previously used paints in the garage.
What you seem to have now is a whole different color of paint on your walls, not a "topcoat" per se.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Tags
glaze , painting , top coat
Kilz Latex Primer & Aura Finish Coat? HenryG57 Painting 7 06-02-2010 04:41 AM
Primer - even coat needed? DaveSD Painting 7 05-10-2010 04:40 PM
partial second coat - did I mess up? matt_ Painting 5 09-22-2009 07:17 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
