What Are These Items On The Roof - Painting - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 03:43 PM   #1
Rewards Points: 31
Hello,
My son has a new house and I don't know what the two side by side items are in the attached photo.
They are above the fireplace pipe. I am sorry for the quality of the picture.
Please tell me what they are.
Thanks,
Randal
sharingsunshine is offline   Reply With Quote
Old 06-27-2012, 03:53 PM   #2
John @ OHFS's Avatar
Those look like bathroom fan vents...
John @ OHFS is offline   Reply With Quote
Old 06-27-2012, 04:29 PM   #3
jschaben
Rewards Points: 502
Look to me like attic vents. Should be some more around the house roof about the same level. The number would depend on the size of the house.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-28-2012, 10:35 AM   #4
Rewards Points: 31
After your help, I went digging and found this link showing what they are.
http://www.homedepot.com/webapp/wcs/...09&R=100344509
Old 06-29-2012, 03:56 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
They are attic vents but they look like they are installed backwards.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-29-2012, 04:14 PM   #6
Rewards Points: 31
thanks for letting me know, is there any ramification to them being backwards?
Old 06-29-2012, 07:03 PM   #7
Rewards Points: 850
the only problem with them being installed backwards is that a professional can see that there installed backwards.
hotrod351 is offline   Reply With Quote
Old 06-29-2012, 07:11 PM   #8
You could get the elements in. Maybe take a look in the attic when it is raining.
Old 06-30-2012, 10:22 AM   #9
Rewards Points: 31
Will do, thanks for all your help.
Old 06-30-2012, 11:12 AM   #10
Rubbin walls since'79
Brushjockey's Avatar
You live where there is wind driven snow and rain? That kind of looks like a hood scoop...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-30-2012, 11:20 AM   #11
Rewards Points: 31
I'm not familiar with a hood scoop. I looked on Home Depot and Lowes site under that name and they didn't have anything. Can you give me a link to what you are talking about?
Old 06-30-2012, 11:27 AM   #12
Sorry- kind of a joke..
You want those vents to be facing down so that it doesn't do what the scoop in that car is doing- funneling everything in.
Actually- just had a brilliant idea- this is the painter forum-look at the top and find the Roofing Forum. They might have a real idea!
Old 06-30-2012, 01:02 PM   #13
Rewards Points: 31
How do you contact a moderator to move this post to roofing? I used an old link that was for painting and I didn't realize it till you said something.
Old 06-30-2012, 01:44 PM   #14
Don't worry about moving- just re ask over there- now you know there vents- ask if it is a problem with the way they are installed- and also say where you are from- that would be important too-
http://www.diychatroom.com/f9/
Old 06-30-2012, 03:13 PM   #15
Rewards Points: 31
OK, I have reposted the question to ask if they are installed correctly. Thanks again for your help.
Insulating flat roof deck paredown Insulation 0 05-15-2012 04:33 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
