What To Spot Prime After Scraping? - Painting - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 12:16 AM   #1
what to spot prime after scraping?
I've heard that all "bare wood" that is exposed by scraping should be spot-primed before painting. But, how small an amount of "exposed wood" does this mean. Sure, there are areas of bare wood inches long. But, also, there are lots of, literally, small "flecks" of exposed wood. Should those be primed, too? If so, i'd pretty much be priming everywhere, which doesn't seem right. In alot of patches, you can't even tell it was scraped unless you look close, but there, you see all these tiny (1mm x 1mm) flecks off.
Any thoughts on how to decide what to prime?
Thanks,
tom
tomcon is offline   Reply With Quote
Old 07-21-2009, 04:50 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Thanks,
tom
I would prime it all with an oil based primer(assuming it is exterior)
to prime or not to prime? re: metal siding... annie68164 Painting 3 05-24-2009 08:58 PM
prime then texture or texture then prime jeerme Painting 8 01-23-2009 10:25 AM
Spot Priming or prime everything? hdtvluvr Painting 2 09-30-2007 08:32 PM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 02:10 PM
