What Solid Stain Is Best? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
View Poll Results: What is the best solid deck stain to use?
Flood 2 18.18%
Cabots 1 9.09%
SW Deckscapes 0 0%
Benjimin Moore 3 27.27%
other 5 45.45%
Voters: 11. This poll is closed
Old 04-12-2009, 11:41 AM   #16
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Rubbol DEK is their classic oil based product. It's been the go to product for a long time. Rubbol Solid DEK is their new acrylic version. It's only been out since this February. I haven't sold any yet and I can't comment on it's performance at this point. I'd say go with the tried and true oil product until there is a some feedback on the new product.
poppameth is offline   Reply With Quote
Old 04-12-2009, 12:03 PM   #17
Is there an advantage of the new?
Thanks I agree to go with what has worked. What is the difference of the two and what are they saying is the advantage of the new one? Is the old one the same formula as it was? Because sometimes they can change the formula and keep the same name. Also was wondering why consumer report ranks sikkens pretty low. They recommend Olympic stain. It gets confusing of what to believe and who to believe.
mpgumm is offline   Reply With Quote
Old 04-12-2009, 08:49 PM   #18
I too am considering a solid stain for my deck (including the highly tauted 'Sikkens Rubbol DEK' / oil-based stain), though a part of me wants to maintain the 'wood grain' appearance that we currently have, though currently weathered. Priorities to me are low maintenance and longevity... which points me toward the 'solid stain', though the prospect of eventual peeling or flaking is a turn-off.
My specific questions... assuming appropriate 'preparation' is done:
1) Does a good solid stain typically 'outlast' an equally good semi-transparent stain'?
2) Is it so that oil-based stains (specifically solid stains) 'last longer' than water based stains?
3) Even if 'maintained' decently, is it inevitable that a solid stain will eventually peel or flake?
4) What are the main disadvantages of a solid (oil-based) stain?
I'm hoping there's a forum member who has broad enough experience on the subject (far more than I do) to help me out. Thanks!
adman is offline   Reply With Quote
Old 04-12-2009, 11:37 PM   #19
Sikkens makes high quality automotive paint. Good reputation in that field.
Stillwerkin is offline   Reply With Quote
Old 04-13-2009, 03:36 AM   #20
This looks so bad. You must have felt like doing something to them
Try lowe's solid stains for deck.
Dana
Dana11 is offline   Reply With Quote
Old 04-13-2009, 06:54 AM   #21
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
The advantages are water cleanup, more environmentally friendly, better color retention and flexibility. The normal stuff when dealing with water vs oil. Waterborne floor coatings have always been sub-par in the past compared to oil. However, with the move away from VOC, the good parts of the oil have disappeared to the point where there isn't much to recommend it anymore. The on thing oil still has going for it is penetration into the wood, but even that isn't the greatest anymore since it's all gove high solids with little solvent left to actually penetrate.
As for Consumer Reports, throw it away and cancel your subscription. At least on the paint end of things, it's always been a joke. They don't test all the aspects that really matter. And they aren't comparing just quality of the products. They are factoring cost in as well. Sikkens costs more than many other products so it gets a lower rating for not being as good of a value.
Old 04-13-2009, 06:58 AM   #22
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yes generally. The opaque pigments provide more protection from the sun and take longer to break down.
That's debatable. Acrylics usually last longer as far as color and retain their flexibility better, but since they get less penetration they tend to peel more readily in certain situations.
Yes, any film forming product will do this. You can only build up so many coats before it will start to peel.
You don't get the rich wood appearance anymore. It looks more like paint.
Old 04-13-2009, 08:41 AM   #23
Set me straight!!!!
Sorry everyone, I am reading so much I am getting confused!!! Please set me straight!!!!!!
Sikkens Rubbol DEK or Rubbol Solid DEK?
Is Sikkens the stain to get, if not what?
Should I go with solid stain, if not what?
Should I get oil based stain?
What prep. solution should I get?
Old 04-13-2009, 11:58 AM   #24
Matthewt1970's Avatar
Rewards Points: 1,098
Solid stains will typicly hold the color longer, but you can always put a solid stain over a semi-transparent stain if the semi doesn't look right. Putting a semi over a solid stain doesn't do much. Semi-transparent stains are better for decks anyways as they don't show the traffic/walking areas as much as solid stains tend to wear away looking more like a semi-transparent in high traffic areas. Solid stains are better for the side of a house. Both are very maintinance friendly as they won't peel and when they fade, just slap on another coat. All bets are off if you use latex. The color may last longer in a latex stain, but it will be in nice little chips that have come up and fallen through the gaps in your boards. You can pop you head under the deck and say "wow, that Latex Stain really held the color"
Old 04-14-2009, 04:07 PM   #25
Sikkens is the best!! A new neighbor recommended it to us after we asked him what he used. It is the only stuff he will use. And he only
owns wood-sided houses.
We had the same problem you had- but we built a new deck when we
put an addition on. After using the Sikkens, we have every confidence
in it. Get the Sikkens!!!
~Oil-based.
bdionne is offline   Reply With Quote
Old 04-14-2009, 07:00 PM   #26
Rewards Points: 336
What stores sell the Sikkens? I couldn't find their website on-line.
gma2rjc is offline   Reply With Quote
Old 04-14-2009, 07:16 PM   #27
The sad thing is that I did prep the deck to the tee that behr recommends on the label. I used all Behr prep products. I sanded the deck, cleaned all dust with their prep cleaner, waited four days to dry completly, and did two coats with Behr Deck plus solid latex stain. I used a **** load of stain. It says one gallon will coat 200-400 sq. ft. but it didn't cover that great. I used a lot more than two gallons. So in a way you buy a cheep can of stain, but end up spending more because it doesn't go on great, so you are buying more cans of stain.
Good news though, I called Behr and complained. They were fighting the claim saying I used too much stain. Just for you to know, if you call to complain, tell them you did everything it told you on the label and that you used the exact amount it told you- because if you don't, they will fight it saying you did it wrong-there for it is your fault. I asked for $300.00 for all the cans of paint, time, supplies, sander, and prep solutions. I have to send in pictures of the can on the deck, pics of the damage, pics of the whole deck, and the upc off of a can. It takes three weeks to process. After complaining how bad of a product it is, they wanted to send a pro out to do my deck with the same stuff I was complaining about. Anyone going through this good luck. My advise, get the money and not another application of a ****ty product!!!! save your upc and or receipt!!!
There is a thread on here about Behr by a Behr rep
You should post there
BEHR would like to hear about your experiences with our paint
Old 04-14-2009, 09:42 PM   #28
He's in there. He has the longest post in that thread.
Old 03-19-2012, 01:51 PM   #29
Rewards Points: 14
I have used Bear plus solid deck stain- two words- stay away! It peeled in places so bad I have to re-do the whole thing. I am looking for the best product so I can get a few years in without having to redo it. I am going with solid because that is what is already there. I need something that will last. I have looked on consumer report.org and they rated Flood Swf solid latex the best- but on all the forums I don't see mention of Flood products- I see a lot of Cabots, SW Deckscapes. Also what is down now is oil-based. Is latex the way to go or do I still use oil-based solid stain. Let me know thank you. (This is for a 20x20 deck)
You NEVER put solid stain on walking surfaces. It is soft skinned and will show wear, peeling and/or cracking within weeks or months.
I have Behr solid stain on the vertical walls of my house (cedar and T1-11 siding) and it has never flaked or cracked in over 10 years!! Yes, it has faded somewhat where hit by the sun for long periods, but otherwise no problem.
I will paint again soon not to cure problems, but to renew the depth of the color.
Curmudgeon555 is offline   Reply With Quote
Tags
best solid stain , latex , oil-based , solid , stains
Best Solid Stain for Siding...? thor Painting 7 08-25-2008 06:52 AM
Solid Stain for cedar doors merlene Painting 2 05-28-2008 06:55 AM
Concrete Solid Stain vs Semi Transparent hgiljr Flooring 5 05-06-2008 06:00 PM
