What Solid Stain Is Best? - Painting - DIY Chatroom Home Improvement Forum
View Poll Results: What is the best solid deck stain to use?
Flood 2 18.18%
Cabots 1 9.09%
SW Deckscapes 0 0%
Benjimin Moore 3 27.27%
other 5 45.45%
Voters: 11. This poll is closed
Old 04-10-2009, 11:52 AM   #1
Question
what solid stain is best?
I have used Bear plus solid deck stain- two words- stay away! It peeled in places so bad I have to re-do the whole thing. I am looking for the best product so I can get a few years in without having to redo it. I am going with solid because that is what is already there. I need something that will last. I have looked on consumer report.org and they rated Flood Swf solid latex the best- but on all the forums I don't see mention of Flood products- I see a lot of Cabots, SW Deckscapes. Also what is down now is oil-based. Is latex the way to go or do I still use oil-based solid stain. Let me know thank you. (This is for a 20x20 deck)
Last edited by mpgumm; 04-10-2009 at 07:37 PM. Reason: It is for a deck not siding
mpgumm is offline   Reply With Quote
Old 04-10-2009, 12:47 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Ugg, sorry to see this. More toubles from a BS third rate product. Stay away from Behr and stay away from Latex stains. Use an oil based stain. Latex stain is really nothing more than latex paint. It doesn't soak in like a stain would so therfore you have way too much sitting on the surface so it is basicly paint. You wouldn't put latex paint on bare wood so don't put latex stain on bare wood. Priming defeats the whole purpose of staining. Using a good quality Oil based stain will last you many years and vs paint, when you are ready to stain again, the old stain won't be peeling off like a paint would.
From looking at your picture you really need to get all that Behr "Paint" off your wall or the stain will no be able to do it's job soaking into the wood.
Matt
Old 04-10-2009, 04:15 PM   #3
Question
thanks! So brand should I use?
What brand is the best for solid stain? I think I still want a dark brown color. I just want the best stain out there so I don't have to do this every year.
Old 04-10-2009, 07:27 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
No question:
Sikkens
slickshift is offline   Reply With Quote
Old 04-10-2009, 07:34 PM   #5
Question
Sikkens?
Sikkens I haven't herd of it. Where do you buy it? Why is it the best of all solid oil-based stains?
Old 04-10-2009, 07:50 PM   #6
slickshift's Avatar
Yeah they are not real marketing savvy as far as the American market goes
They tend to be pretty specific and accurate, which Americans don't care for
Plug Sikkens into your favorite internet search engine, you should find their site
And get a local dealer
Why?....I'm not a chemist so I couldn't analyze it in that way
But truly, I've been using their products as a go-to problem area solution for years
They will want you to remove what is there
Regardless of your choice, even if they don't say so, you need to get rid of that horrid Behr
Sikkens will insist on it..the others should, but many consumers don't want to hear that so the manufacturers (marketing really) leave that part out as to not lose sales
I would remove any/all possible at whatever cost/effort and re-coat with 2 coats oil Sikkens
Old 04-10-2009, 10:01 PM   #7
You did not prep your deck, you have to sand, de-mold, wash and then blow clean it.
No stain will work if you do not prep the surface.
fmeijler is offline   Reply With Quote
Old 04-10-2009, 11:38 PM   #8
Ya Sikkens is good stuff, and they have a boat load of colors to choose from so you should be able to find the right brown.
Old 04-11-2009, 12:23 AM   #9
Rewards Points: 180
How many years does the Sikkens last before the deck has to be re-sealed?
I used the 'One-Time-Wood' sealer ( www.onetimewood.com) on my decks in the spring of 2007. It's gauranteed to last 7 years. Looking at it today, I'm not so sure it's going to make it through this spring. It sure isn't looking very good.
gma2rjc is offline   Reply With Quote
Old 04-11-2009, 06:55 AM   #10
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Sikkens doesn't put a stated time frame on their product. It depends quite a bit on the amount of sunlight it gets. I've seen Rubbol go as much as ten years without needing a recoat if it's in a well shaded area.
poppameth is offline   Reply With Quote
Old 04-11-2009, 08:50 AM   #11
The sad thing is that I did prep the deck to the tee that behr recommends on the label. I used all Behr prep products. I sanded the deck, cleaned all dust with their prep cleaner, waited four days to dry completly, and did two coats with Behr Deck plus solid latex stain. I used a **** load of stain. It says one gallon will coat 200-400 sq. ft. but it didn't cover that great. I used a lot more than two gallons. So in a way you buy a cheep can of stain, but end up spending more because it doesn't go on great, so you are buying more cans of stain.
Good news though, I called Behr and complained. They were fighting the claim saying I used too much stain. Just for you to know, if you call to complain, tell them you did everything it told you on the label and that you used the exact amount it told you- because if you don't, they will fight it saying you did it wrong-there for it is your fault. I asked for $300.00 for all the cans of paint, time, supplies, sander, and prep solutions. I have to send in pictures of the can on the deck, pics of the damage, pics of the whole deck, and the upc off of a can. It takes three weeks to process. After complaining how bad of a product it is, they wanted to send a pro out to do my deck with the same stuff I was complaining about. Anyone going through this good luck. My advise, get the money and not another application of a ****ty product!!!! save your upc and or receipt!!!
Old 04-11-2009, 09:09 AM   #12
give me the best brands
anyone that has a pick of their best solid 0il based stain for outdoor deck let me know. Just give me the brand name and or company. Would love to get as many opinions as possible. Thank you to all that reply. I am a little obsessed with this considering all the time and money I have gone through the last two years staining my deck- only to be exactly the same place I was at the beginning (a horrible looking deck-thanks Be hr) I appreciate all comments to help me have a stain job that will last me more than a year. So I can spend weeks during the spring doing something else than stripping and staining my deck!!! Hopefully I can save someone from the same headache
Old 04-11-2009, 09:59 AM   #13
Rewards Points: 252
sikkens is absolutely great stuff - expensive but cheaper in the long run if you consider labor. Ben Moore makes a great solid deck stain as well - you might also want to look at a product by MAD DOG Primer called deck fix which would be applied prior to putting a solid body deck stain down.
mazzonetv is offline   Reply With Quote
Old 04-11-2009, 04:35 PM   #14
Mad dog? What is it, a primer? What does it do help the solid stain add-hear better? I herd that primer just seals the wood too much where it can't breath, is that true. Let me know the best thing to prep with. I know Prep. is just as important as the stain itself. Love to hear any suggestions of prep. products. prep. steps, and of course type of stain. Man I am really starting to lean towards going with sikkens do to all the comments on it. Is it that good? I am not a painter so any suggestions, tricks, etc. is highly appreciated. Want to get going on the deck soon because I can't bear (behr) ha ha to see it in the condition it is in. Keep tracking hunks of stain into the house. Just want to start over right and next spring/summer have a extra two weeks to do something else than stain a deck. Thanks guys.
Old 04-11-2009, 10:12 PM   #15
Which Sikkens product?
Looked at Sikkens site. It seems like I have two choices for a solid stain. Rubbol Solid DEK or Rubbol DEK Not sure what the difference is between the two. If you know about Sikken products let me know.
Tags
best solid stain , latex , oil-based , solid , stains
Best Solid Stain for Siding...? thor Painting 7 08-25-2008 06:52 AM
Solid Stain for cedar doors merlene Painting 2 05-28-2008 06:55 AM
Concrete Solid Stain vs Semi Transparent hgiljr Flooring 5 05-06-2008 06:00 PM
