What Should I Use For A Skim Coat? - Painting - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 10:08 AM   #1
What should I use for a skim coat?
I just want to skim coat and paint. What should I use? Joint compound? Multi-purpose compound? I don't have a clue ...
Please help...
Thanks!
Double A. is offline   Reply With Quote
Old 12-11-2011, 10:35 AM   #2
Gymschu's Avatar
Rewards Points: 662
Prime first with Zinsser's Cover Stain.....yes it stinks but you have staining on that wall that will wick back through the joint compound. I prefer Topping Joint compound for skimming purposes because it's much easier to sand. Been doin it that way for 20 years or so with no problems. It's a fun job, skimming, that is!
Old 12-11-2011, 10:41 AM   #3
Thank you do much for your help!!! :-)
Old 12-11-2011, 10:42 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
All the above plus powdered setting type mud can all be used to skim- but each has it's own qualities.
i see you are down to bare old plaster.
First fix cracks- I like to stabilize with sheetrock screws on either side of a crack, screen tape, set tape with powdered mud, second coat (widen out with 12" blade) with either powdered or topping, full skim with topping like plus 3.
if there is old paper paste or any question of adherence to the plaster, i would give it a quick stabilizing prime first with Zinsser Gardz.
this is a tough job for a first timer btw- I have spent years perfecting my procedure.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Skim Coat Tools? Knives, Trowel, or Magic Trowel?? Lovegasoline Building & Construction 7 08-01-2012 10:25 PM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 06:30 PM
Plaster over Skim Coat Canoe Place Drywall & Plaster 0 08-22-2011 03:13 PM
skim coat over skim coat? drke Drywall & Plaster 0 11-28-2010 09:07 AM
Skim Coat on Ceiling is Bubbling JerMann Painting 19 09-13-2010 09:37 PM
