What Is The Proper Product To Clean A Previously Painted Wood Door Prior To Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 05:41 PM   #1
Rav
Rewards Points: 542
Question
What is the proper product to clean a previously painted wood door prior to painting?
I have a wood panel door, previously painted over 20 years ago, which I want to repaint. I think latex was used, but I'll check by rubbing a small area with alcohol to see if it rubs off (latex).
The door is quite dirty (it separates the basement from the garage). I want to clean the door prior to (and after) light sanding. Assuming the existing paint is latex, would denatured alcohol be the correct thing to use? How about rubbing alcohol (which I happen to already have)? Or should I use trisodium phosphate? I've seen references to both alcohol and TSP but am not sure which is more appropriate in this situation. Thanks.
Rav is offline   Reply With Quote
Old 07-23-2012, 05:43 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Dirtex
also comes it spray cans
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (07-24-2012)
Old 07-24-2012, 07:43 AM   #3
Gymschu's Avatar
Rewards Points: 178
.......and sometimes just warm water and a damp rag are all you need. Sometimes using all the cleaners with chemicals in them leaves a residue if not properly rinsed off.
Old 07-24-2012, 08:24 AM   #4
Too Short? Cut it Again!
Alcohol would be overkill. And never use rubbing alcohol as a cleaner as it contains lanolin which will remain on the surface.
Do not use any more moisture than you have to on any wood door.
Old 07-24-2012, 11:02 AM   #5
Rav
Rewards Points: 542
Thanks for all the responses. Dirtex (powder) looks like the best thing to me so that's what I'm going to use.
Old 07-24-2012, 11:57 AM   #6
chrisn's Avatar
Rewards Points: 120
Be sure to rinse well.
Tags
cleaning , door , wood
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
cleaning and painting exterior raw wood shorty46 Painting 4 06-18-2008 06:14 PM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
Repairing the wood for painting bofusmosby Painting 4 06-17-2007 12:55 AM
Sanding previously painted woodwork MWM Painting 7 09-25-2005 11:37 PM
