What Primer For A Skim Coated Wall - Painting - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 05:48 AM   #1
What primer for a skim coated wall
My Wife and I are remodeling a powder room. The room had some very glossy paint and some damage on one wall. We patched the wall and primed with Muralo Stain-blocking/bonding primer and the paint lifted and peeled off in sheets. We scraped the entire wall until we had a sound surface and skim coated the whole thing. I'm thinking of using Kilz Odorless oil-based primer on the skim-coated wall so it doesn't lift again but wanted to get the thoughts of some experts. Thanks.
slickracer is offline   Reply With Quote
Old 12-09-2009, 07:48 AM   #2
Remodeling Contractor
use a pva primer or zinsser's 123 primer
Old 12-09-2009, 08:39 AM   #3
(the original)
Rewards Points: 756
Originally Posted by slickracer View Post
very glossy paint
Did you clean and sand or degloss? Sounds like lack of proper prep to me.
I can't get Muralo here, as its a regional brand, but what I've read about it is positive. I doubt that's the problem, but if you choose to change products, Bullseye 123 will work fine.
ratherbefishin' is offline   Reply With Quote
Old 12-09-2009, 04:57 PM   #4
I did degloss and wash with Dirtex. The problem was there were a few layers of paint and the bottom layers lifted.
Old 12-09-2009, 06:02 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
I would ditch the Kilz and stick with the Muralo, much,much better product.
Old 12-15-2009, 11:28 PM   #6
Rewards Points: 530
You guys may have more experience than me. What caused the bottom layers to lift?
Shouldn't this be addressed to avoid the same thing from happening again? Moisture? Top coat pulling the older paint off? Maybe the older paint was not prepped properly?
Old 12-16-2009, 03:58 AM   #7
chrisn's Avatar
Rewards Points: 312
Absolutely, you must have a sound surface to work with
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
