What Primer Should I Use? - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 05:26 PM   #1
What primer should i use?
Hi all, new to this forum and to painting. I am repainting the all of the walls in my home. They are old plaster walls with cracks and holes and an ugly orange peel texture. I am attempting a level 5. Probably end up with a 4.x. Anyway I have the skim coat on in one bedroom and I have taken pain staking efforts to make it perfect. Shooting for no imperfections. Plan on using a SW eggshell paint and was wondering what the best primer would be to get the smoothest finish. I have read that gaurdz can be used as primer with awesome results. Any recommendations will be appreciated.
Jyncks is offline   Reply With Quote
Old 07-20-2013, 07:35 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Guardz is more for a moisture barrier. When you are at SW get a gallon of the Promar200 primer. Great stuff.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-20-2013, 07:47 PM   #3
Thanks for the reply Matthew. do you have an opinion on their Cashmere paint? It says it level nice and is good for beginners.
Old 07-20-2013, 07:51 PM   #4
Rewards Points: 582
sw promar paint and primer are great products for pros and homeowners alike...ben sr
Old 07-20-2013, 08:31 PM   #5
Thanks Ben. I`m heading there tomorrow for their 40% off sale.
The Following User Says Thank You to Jyncks For This Useful Post:
ben's plumbing (07-20-2013)
Old 07-20-2013, 08:59 PM   #6
Painting Contractor CT
Rewards Points: 77
Post
Zinsser 123 primer works great as well..Good Luck!
KD PAINTING is offline   Reply With Quote
Old 07-20-2013, 10:07 PM   #7
I actually tried 123. It left a bad orange peel on the wall. I`m sure it was due to my technique more than anything. That stuff just would not sand well for me. I had to skim coat the wall again. Thought I`d give something else a try.
Old 07-21-2013, 08:37 AM   #8
Thanks for all of the replies. I think I`m going to try the Gardz and 2 coats of Cashmere out. I'm sure all of the products mentioned do a fine job with the right tools used in the right hands. I'm a noob and I'm sure there's going to be some trial and error before I find what works best for me. I don't mind spending the extra money. I firmly believe in you get what you pay for. Enjoy your Sunday.
Old 07-21-2013, 08:41 AM   #9
A Little Of Everything
Rewards Points: 1,364
^ Don't be thrown by it, if you get a can of the "clear" Gardz. It looks a touch milky going on, but dries clear. It's not your typical primer. You might also have to be extra careful to avoid any roller lines.
Light touch. You'll do fine!
DrHicks is offline   Reply With Quote
Old 07-22-2013, 09:14 AM   #10
I am not taking sides here. I have read that using gardz will work great for a primer on alot if sites. Jack Pauhl (don't know him from Adam) did some testing with primers. He had alot of pics showing different things used as primer. The photo showing gardz used as primer was awesome. What are your reasons for not using gardz? The only downfall i can see so far is it's thin and tricky to apply. But like anything, alittle practice and....
Old 07-22-2013, 12:56 PM   #11
Jmayspaint's Avatar
Rewards Points: 534
Jack Paul's primer tests are very interesting to me also. Having used many different drywall primers over the years, I really think most of them are worthless. Some like Zinsser 123 actually seal the surface. I haven't used Gardz yet, but from what I've read and seen it does seals the surface.
Jmayspaint is offline   Reply With Quote
Old 07-22-2013, 02:24 PM   #12
Rewards Points: 394
Although the primers here are fine, a level 5 finish is achieved by using a specialty high-build primer. It provides a level 5 finish, which does not show the tape joints and seams.
Will22 is offline   Reply With Quote
Old 07-22-2013, 03:30 PM   #13
Pauhl says you can get a level 5 with Gardz. There is no doubt everyone on here knows a lot more about this than I do. I don't think that I need a high build because of the effort that I am taking to make sure there are no imperfections. Using a bright lite and endless sanding, I'm sure due to my inexperience with laying mud on walls. I'm going to try the Gardz and see what happens. Until then, the sanding continues.
Old 07-22-2013, 05:35 PM   #14
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
You will never, ever get a level 5 finish from a primer. The wall needs to darn near perfect before any primer goes on. Also, don't believe everything you read on JP's site
Old 07-22-2013, 06:16 PM   #15
I would say a level 5 is more to do with the prep more than anything else. But certainly a product of the whole process. Being a first timer, I don't expect to get a perfect finish but rather, the best I can get doing it myself.
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 06:03 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
