What Is Popcorn Ceiling? - Painting - DIY Chatroom Home Improvement Forum
Old 10-25-2009, 07:06 PM   #1
what is popcorn ceiling?
It would attract birds wouldn't it?
nerd_flanders is offline   Reply With Quote
Old 10-26-2009, 08:46 AM   #2
Too Short? Cut it Again!
Nerd. Not sure if you are just looking for an audience for bad humor but I will assume the best in you...
Popcorn ceilings are the unholy work of the devil. They were---still are unfortunately---popular for surfacing ceilings because they do not require skim coating of drywall seams and do not require painting (so long as boring white ceilings are alright with you). In most cases, a slurry of finish with little polystyrene (or something plastic) beads is sprayed directly on to unprimed drywall to leave a textured look that among other things, hides uneven joints and crappy drywall taping.
When ceilings develop water leaks or poorly taped seams give loose, you not only have to make repairs but you have to try and match the texture.
Also, because the stuff was sprayed on with no primer to adhere to, it tends to come off in large chunks (especially if it has dried out) if you put any surface tension on it at all---say from a paint brush or roller. As a result you cannot count on being able to paint it and more often than not you end up with pieces of a ceiling stuck to your painting tools.
There are cludges for this but no real fixes that are at all fun or practical. More often than not, we end up scraping the entire textured ceiling, skim coating, sanding, priming and painting. As should have been done in the first place.
Old 10-26-2009, 09:54 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
only if it was an afterthought applied by the patrons at the local theater while bored waiting for the movie to start.
I guess that means I should never go to a live performance of A. Hitchcocks, The Birds
Old 10-27-2009, 03:30 PM   #4
Drywall contractor
Rewards Points: 1,070
Textures are for those who can't finish drywall.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-27-2009, 03:38 PM   #5
Rewards Points: 518
Just one comment on this - most manufacturers of popcorn spray texture highly recommend using a white primer on the ceiling prior to application to avoid the texture falling off and to ensure even and consistent color.
Even further to that, many people mix in a cup of white latex paint in their batch to brighten the texture and increase durability.
However, in the real world of the trades I have little to no experience and I'm sure anyone in a hurry since the 1970's easily got away without a prime coat.
n0c7 is offline   Reply With Quote
Old 10-27-2009, 04:25 PM   #6
Drywall contractor
Speaking from 35 years in the trade, I can say that the only time I personally have primed a ceiling before spraying with acoustic is when the mfgr's. first removed asbestos from the formula. The new spray didn't cover well so we "flash" coated with the cheapest white latex we could find (priming didn't pay any extra). Price dictates the amount of prep. Builders don't want to pay for primer. A sprayed acoustic ceiling is a done deal, no primer before and no paint on top. Same with "stipple", it is a finished product over raw sheetrock. The builder doesn't have to pay the painter to prime and finish coat with paint.......
Old 10-27-2009, 05:46 PM   #7
Rewards Points: 518
Now I'm starting to see why people hate it so much. Do you have a picture of what a "stipple" ceiling looks like?
Old 10-27-2009, 05:54 PM   #8
Welcome to my entire House !! Hate it
Skunk is offline   Reply With Quote
Old 10-27-2009, 06:03 PM   #9
Drywall contractor
Don't have a pic, but a search here or on google will get results. It's not much better than "popcorn", but is more durable....
Old 10-30-2009, 02:16 AM   #10
We have similar stuff in our country.
My last palce had this sprayed ceiling. it was like slurry sprayed on and it comes off if you graze it. It DOESNT resemble pop corn in any way shape or form.
It used to have asbestos in it years ago but they don;t do that since the 70s.It actually looked okay , was sound proof and needed no maitenence, because it was done right , the joins didn't open up after all these years, and it also had glitter in it.
but usually that stuff is a night mare to deal with .
But y would anyone call it popcorn?
Old 10-30-2009, 02:18 AM   #11
yes i was joking, but also want to know what the answer is .
Old 10-30-2009, 11:14 AM   #12
yummy mummy's Avatar
Rewards Points: 1,016
Thatt is so true in my case, but only for my ceiling, as I had to cut the drywall into 3 pieces in order to get it up there, so I had soooooooo many seams to cover that I did a hand textured ceiling. I did tape and do a first coat though.
But my walls came out very good, in fact, even better than the upstairs that was done by a pro about 6 years ago.
Mind you the pro took a few days and I took six months.......
yummy mummy is offline   Reply With Quote
Old 10-30-2009, 04:15 PM   #13
Matthewt1970's Avatar
Rewards Points: 1,098
Old 10-30-2009, 07:24 PM   #14
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
Sir MixAlot is offline   Reply With Quote
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
Popcorn ceiling - hazardous to your health? pwrpro Building & Construction 3 01-10-2009 12:56 PM
scraped the popcorn off the ceiling, and tore through the paper-now what chapito Painting 6 07-18-2008 10:17 PM
popcorn ceiling painting phil334 Painting 2 07-11-2008 11:23 PM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 01:33 PM
