Old 08-01-2007, 07:46 PM   #1
What paint to use on new england house on the ocean
I am painting the trim on a house that is right on the ocean. What is best paint for durability to harsh NE winters?
bmfay10 is offline   Reply With Quote
Old 08-01-2007, 08:24 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Although the premium exterior products from Ben Moore and Pittsburgh are excellent, I give a slight edge to Duration from Sherwin Williams for this case
...and I should mention I am not a SW fanatic, I've used far, far, more Ben Moore than Sherwin Williams over the years, and I really like the Pittsburgh premium exterior paints
But for my own exterior (and you can see by my location I'm out in the ocean), I went with the SW Duration
slickshift is offline   Reply With Quote
Old 08-01-2007, 08:32 PM   #3
I'm a Ben Moore guy as well, never even think of SW. I was considering Pittsburgh Sunproof, but I'm still researching. I'm painting trim that has many previous coats. I just primed w/ Kilz, which I usually use sparingly. You we're happy w/ Duration though?
Old 08-02-2007, 06:53 AM   #4
poppameth
Guest
Posts: n/a
Pratt & Lambert Accolade. I'm not usually a huge fan of the stuff since it can be difficult to work with, but from my understanding it's used a fair bit in Hawaii and holds up the salt spray better than any similar product on the market. I haven't heard of any complains due to extreme weather either.
Old 08-02-2007, 02:16 PM   #5
slickshift's Avatar
Yes
Happy enough with it in a professional capacity to strongly recommend it for houses in tough environments (like on the ocean), and tough substrates (like old over old, questionable, paint or peal prone problem areas)
It's "self-priming", which I don't use as an excuse not to prime if needed
(there's simply no substitute)
However, the extra adhesion does help in problem areas
Normally I'd let the customer decide BM MoorGlo/Soft/Gloss, Pittsburgh Manor Hall, SW Duration...they are all pretty good
If it's on the water, has a few layers, or is (relatively) wet or old/weathered, or has previous pealing issues (not due to being a "wet house"-dampness from the inside out or something else major), or there are other concerns, I usually recommend the Duration
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
my painter did not fallow the contract jaskoo Painting 17 11-19-2006 02:21 PM
exterior paint question sherlock Painting 5 07-05-2006 08:31 AM
