Old 12-25-2007, 11:15 AM   #1
Question
What paint to use first?
I'm starting a large home that has been painted with oil paint on all trim and latex on the walls. The ceilings will be painted in flat latex. Walls in satin latex,and All trim in oil,doors,moldings and windows. The edges of trim will be painted in oil. Would you start cutting in the walls first,covering the baseboards with tape? Or start with the oil paint? Started this topic on Pro site by mistake.
Dougit is offline   Reply With Quote
Old 12-25-2007, 01:31 PM   #2
Oldguy
Rehabber's Avatar
Ceilings first, then walls, trim last
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-25-2007, 03:23 PM   #3
Hi Doug,
As rehabber said above it's best to paint the ceilings first. We do that so that if there is any splatter from the ceiling on the walls it can be sanded back, if needed, and then painted over with the wall colour. If you intend on painting the trim there really isn't any need to tape it off before painting the walls. I would only tape the trim if I wasn't painting it to protect it from splatter.
Cheers
Mary
mdancey is offline   Reply With Quote
Old 12-25-2007, 04:49 PM   #4
Professional Handyman
If you have a good, steady brush hand, paint the trim after the walls. But, if you're not that good and don't want to tape, then paint the walls first but don't cut-in the edges near the trim. Next, paint the trim. Lastly, cut in the walls. The difference? It's generally easier to paint straighter and neater if you're facing the broader edge of the wall than along a narrow edge and on an angle that partially obscures your line of sight. If you're experienced and have good technique, then cutting trim after-the-fact shouldn't be an issue.
End Grain is offline   Reply With Quote
Old 12-25-2007, 06:19 PM   #5
Pro Painter
STOP, AND SLOWLY BACK AWAY FROM THE WALL!
Paint ceiling, Trim and walls.
Paint the walls before time is not a good idea.
Cutting in from the wall surface is a lot easier than from the trim.
Believe me i have been doing this for a while.
Troy
TroyM is offline   Reply With Quote
Old 12-25-2007, 06:31 PM   #6
Too funny. As you can see there are many different techniques used all to reach the same end. Some days I do the trim before the walls and on other days I do it the other way around.....just depends......on what I do not know. If you're just starting out, then painting the trim first then the walls might be best. If you splatter any wall paint on the trim it's easy enough to touch it up after you're done.
Cheers
Mary
Old 12-25-2007, 10:14 PM   #7
Thanks for the info! Can you use latex kilz primer to cover nail holes filled with wood putty over the trim. Oil paint will cover trim? I haven't painted in a long time.
Old 12-25-2007, 10:15 PM   #8
Workaholic's Avatar
What ever way is going to make you feel most comfortable. I myself can do it in any order, but when i am doing new construction, or a full repaint. I go ceilings, trim, And walls.
Sean
Workaholic is offline   Reply With Quote
Old 12-25-2007, 10:28 PM   #9
Pro Painter
Yes, but you want to teach best ways possible.
Using good quality roll, brush and paint, should help keeping splatter to minimal.
Having done painting day in and day out, doing trim before walls, IMO, is the fastest and the best way to achieve a clean/ straighter line between the trim and walls.
Troy
Old 12-25-2007, 10:31 PM   #10
Pro Painter
That will be fine.
Troy
Old 12-26-2007, 11:46 AM   #11
Kilz Latex is evil! If you are already using oil paint, I'd use oil-base primer, like Original Kilz, to go with it. (There are fine water-base primers, but Kilz water-based isn't one of them. Get your paint and primers from a paint store, and you will be much better off than BigBoxCo.)
SirWired
sirwired is offline   Reply With Quote
Old 12-26-2007, 09:25 PM   #12
Are most oil paints the same? The big box stores only carry one brand. They have done away with most oil paints. Does BM or SW have one better then the other? Can one get away using an oil paint as a primer over nail holes. or will the nail holes show up after oil paint has dried on trim like latex satin paints on walls , if not primed over ?
Old 12-27-2007, 09:24 PM   #13
Pro Painter
Go with BM "satin Impervo oil" and you will not be disappointed.
On the nail holes part, you just need to test it yourself.
It is hard to tell without seeing the holes.
Old 12-29-2007, 08:00 PM   #14
It matters not what the big box stores carry or do not carry. Do not buy your paint there. Both BM and SW have multiple oil-base interior finishes. Some are enamels, some are paint. The ones most commonly used for interior trim are SW ProClassic and BM Impervo. (Both are available in Waterbourne and Oil formulations.)
SirWired
Old 12-29-2007, 10:59 PM   #15
Tired, Cold, and Damp
slickshift's Avatar
No
I'm surprised the Big Boxes in your area have any at all
They have done away with all oils at my local Big Box
That's OK, because most all Big Box paint is severely lacking in quality anyway
SW seems to have discontinued oil-based paints in my area
I'm sure it would be on quality with the comparable BM if it were available
Paint makes a lousy primer
That's why they have primer and paint
slickshift is offline   Reply With Quote
How should I paint this room? LeroyFrick Painting 8 10-30-2007 06:09 PM
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 10:29 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
exterior paint question sherlock Painting 5 07-05-2006 08:31 AM
