Old 11-23-2010, 12:53 AM   #1
What to paint over previously painted basement walls
Basement walls are concrete block and have been painted at some point in history with a lime green paint. Appears to be oil based and lead tests have been negative. I want to repaint and realize since it's already been painted, DryLock isn't an option, so what's the best paint to use in this situation? It's just an unfinished basement, but needs freshened up.
Atskodinski is offline   Reply With Quote
Old 11-23-2010, 04:30 AM   #2
paper hanger and painter
chrisn's Avatar
A quality bonding primer, then anything you want, 100% acrylic latex would be my choice
Old 11-23-2010, 05:02 AM   #3
Hear here, I agree with chrisn.
Personally I would remove as much of the original covering as I can, but then Im a dye hard.
A good bonding primer first and then go mad - Accrylic PVA - would be my first choice too.
Enjoy!
Alistair is offline   Reply With Quote
Old 11-23-2010, 11:17 AM   #4
I guess by following said advice I'm just going to have to live with the fact that the walls won't be moisture locked with a drylock type product and that my painting is more asthetic in nature?
Old 11-23-2010, 11:57 AM   #5
(the original)
You don't give any indication that you actually have a moisture problem.
Is the original paint peeling, bubbling, flaking, falling off the walls?
ratherbefishin' is offline   Reply With Quote
Old 11-23-2010, 02:12 PM   #6
There are a few spots where moisture appears to have been an issue at some point in time. One spot was particularly bad with mold, and that issue is being rectified. The majority of the walls are in good shape though. I'm going to be filling all cracks and crevices with hydraulic cement or masonry caulking depending on the size. Then I'll paint over the walls. If I go with the priming option, would Killz be an adequate choice? Should I use different products over the sections that show problems?
Old 11-25-2010, 07:33 AM   #7
chrisn's Avatar
Avoid kilz, use one or the other of these
Old 11-25-2010, 12:11 PM   #8
Thanks! I guess those would block any stains on walls? How pricy are these out of curiousity?
Old 11-25-2010, 06:08 PM   #9
Painting Company, NY
housepaintingny's Avatar
I would use SW Shercrete as it is an actual waterproofer available in any color you want, its acrylic, flexible, breathable, and will bridge smaller cracks. No primer will be needed with this product, but first scrape off any loose paint.
housepaintingny is offline   Reply With Quote
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Paint removal from concrete in basement ridofpaint Painting 3 04-06-2009 09:57 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
