what to paint first
main question is: should i paint the walls or trim (incl crown) first?
this is a kitchen, so i'll also be painting around my new 10k cabs. my nerves are already warming up just thinking about getting paint near them. using latex on everything. the trim is factory-primed, the walls are bare drywall paper + mud. also appears that most prefer no tape... any tape fans with reasons? thanks |
The walls and trim should have been painted before the cabinets ever got installed. Now you will have to cover the cabinets with plastic, same with the counters and get to work. Ceiling first, then walls, then trim, in that order.
Why where the walls not primed and painted before the cabinets went in?
Now you stuck with having tape and cover everything with plastic before painting. Ceiling, all the trim, then prime and paint the walls. Always cut in before rolling. |
Paint walls first, then trim. Tape off and plastic cabinets do not use drop cloth as most from DIY stores are not plastic backed. When you paint trim use an expensive angled brush for latex and cut in carefully by hand, tape almost always seeps paint. When your cutting in with a brush by tape treat it as if the tape is not there be careful and try not to get paint on it, it is an extra precaution not a blocker.
Sorry gregzoll we must have pushed the button at the same time we were having the exact same thoughts. Strange.
As you see , there is more than one way to do things.
But understand, it is about systems. Usually I try and prime walls/ceiling before cabs, but it wasn't done that way. I would still prime them first. If you do trim next- you don't have to worry about getting it up on the walls, that will be fixed later. Finish completely. Then tape off base and anything that "gravity" will get splatters on. Finish ceiling, then cut wall paint to trim and ceiling, and your base is taped off so easy cut there. Big problem with tape is bleeding underneath. Use a putty knife to seal tap down . Might be worthwhile for a newb to use frog tape for this reason. Pull tape after paint sets and clean up lines. |
firsttimereno,
I know the guys gave you good advice, they know what they say...it's a shame you got everything done kinda backwards so that your job now will be harder...I know pro painters hate using tape...but...I just painted two room (after the ceiling) and I used Frog Tape. I used tape once before many years ago, and it did 'leak' and swore no more...but I read so many good things about the Frog Tape, I tried it...worked great, no leaks at all...I pressed it down really hard along the edge where the paint was going, and left the top 1/4" just barely stuck to the ceiling...so the paint part did it's job and it was easy to take off...I left it on until the next day and really, it came out perfect. One of the rooms has crown moulding...I waited a full day then taped the wall under the moulding, pressing hard just under the moulding, and kept it barely stuck below that point...painted the crown moulding...waited a full 24 hrs, pulled off the tape...another perfect job. This will at least give you some 'food for thought'. Good luck with your project! |
1. prime walls.
2. paint ceilling 3. paint trim 4. paint walls i caulk my trim and putty the nails hoes and "slop" the trim paint on then i cut a nice line with the wall paint. |
I would tape the cabinets where they meet the walls 1st before doing any painting in the kitchen, take the time and do a perfect job when applying the painters tape to ensure a seamlest paint line. Then cover your new cabinets with a thin plastic poly and secure with a painter tape to hold in place to avoid paint splatter for the entire dutration of this project.
1-With the trim, base and crown factor primed I would paint these with 1 or 2 coats of the finish before they are installed, this is much easier to do when they are on saw horses and your not crawling around the floor or on a ladder. 2-prime all the areas that will require 3-Complete the ceiling painting 4-Roll the 1st coat on the walls, this will avoid the need to cut in with a brush at the wall where it meets the crown, trim and base 5-Install the new trim and caulk seams and gaps with Alex Plus paintable dap caulking, fill all nails holes and sand smooth 6-paint the base, trim and crown with the final coat, make sure you cover the dap caulking with the trim paint and do not worry to much if the trim paint get on the walls 7-2nd coat of wall paint, this is where you will need to cut in along the trim and to cover any spots where you have previously hit when painting the trims finish coat, it is much easier to cut the walls to the trim then it is to cut the thin edge of the trim to the wall. 8-Remove the plastic and crack the case of beer! |
yup thats exactly what i mean. got to be careful so nobody takes me literally with some of my slang.
thanks for all the replies. too bad everyone is providing a different order. yes, i know i SERIOUSLY screwed up not painting first. :wink: 7' cabs with 8' ceilings + crown... its gonna be a whole lotta fun trying to paint now....
sorry, forgot to explain ceiling is completely finished and top-coated. at least that was done before cabs. so... pros/cons of walls before trim, or trim before walls? any more input? basically what i'm gathering is, that if i do the walls first i'll have to use tape when i do the trim. if i trim first, i can cut in the walls without tape, just steady-hand it. i agree with some of you, it seems like cutting in trim after walls are painted would be tough, especially without tape. gonna frogtape the hell outta the cab edges. i've always pulled tape after each coat, before it dries, causing multiple re-tapes. lotta work, but scared to pull off finished paint edge if i wait till its dry or multiple coats on same tape edge. could leave same tape throughout all coats, and maybe lightly score edge before removal, to avoid peeling the coat (?) |
yes:yes: |
what to paint first
Agree with Pricelake on this one
You can cover area with plastic to avoid cleaning any drips. Good Luck! http://www.kdpaintingct.com |
| All times are GMT -4. The time now is 06:34 AM. |
