What To Paint On Double-hung Sash? - Painting - DIY Chatroom Home Improvement Forum
Old 08-04-2014, 04:34 PM   #1
Unhappy
What to paint on double-hung sash?
If one is perverse enough not to use replacement vinyl windows, what do you leave unpainted on wooden sash, once you've stripped them to the bare wood? "Wood against wood" is what I've always heard, but I find the painter in 1898 painted the top of the upper sash, which certainly goes against the frame. In the other house (1890) the rebates for the glass were unpainted and unprimed, whereas I've always painted them three coats. The people who are in the sash-making business in Indianapolis will prime the whole surface if you don't stop them. Maybe latex paint doesn't get sticky in hot weather.
Is there a good way to keep the bottom of the lower sash from rotting? I'm having to throw out every other one because they're too far gone to fix with wood filler.
Ed Ferris is offline   Reply With Quote
Old 08-04-2014, 05:18 PM   #2
Rewards Points: 6,652
Paint with a good primer and paint after getting the wood cleaned of any old paint & dirt. You really do not need three coats of paint, if you do it correct the first time.
Old 08-05-2014, 03:10 AM   #3
Double-hung windows are usually painted in two stages. The interior surfaces are painted with interior-quality paint; the exterior surfaces, with exterior-quality paint.
Thomes is offline   Reply With Quote
Old 08-05-2014, 08:29 AM   #4
Jmayspaint's Avatar
Rewards Points: 534
I think your right about not painting wood on wood for the most part. The edges of the sash, and the tracks are often left unpainted.
One way you could go about it is to take a cue from modern windows. Look at the painting specifications for Anderson double hung wood windows, that could give you an idea of what not to paint. On some models, it voids the warranty to paint the edges of the sash, etc..
The areas left unpainted are treated with a clear paintable waterproofer to prevent rot and decay.
Here's one waterproofer that might work, though I haven't personally used it.
http://www.ktc.uky.edu/kytc/kypel/do...?fileIndex=573
Jmayspaint is offline   Reply With Quote
Old 08-07-2014, 03:51 PM   #5
Smile
What the Victorians did
It's kind of funny that the unpainted sides and tracks on these old sash are in great shape and the painted parts are rotten. As I mentioned, what really gets bad is the bottom edge of the lower sash. Maybe making channels in the stool (if that's what the bottom of the frame is called) would help it drain.
Although the Victorians did have spar varnish, the contemporary practice was to wax the running surfaces.
I'm tempted to make the replacements out of red cedar and not paint them at all. We used to use unpainted redwood in the hippie days out in California, but for casements.
Lead Paint Follow-Up RoughDraft Painting 24 06-18-2013 08:31 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
